Question about Arcade Golden Tee Unplugged Video Cabinet
My golden tee freezes when i hit the ball in certain place and restarts
    Problem Solver:
  • 7 Answers
The first and easiest thing to check is the voltage supply to the game board. This should be 5 VDC, but may need to be 5.1 VDC as some games are a bit fussier.
Using a digital multimeter check the voltage from the switching power supply in the cabinet, which will be a medium sized metal box with multiple wires attached to it, and the two wires you need will be clearly marked '+5 VDC' and 'ground' or 'common' or 'negative'. If the voltage is incorrect there will be a small potentiometer or knob that can be turned to adjust the voltage. With the multimeter still connected adjust the voltage so the multimeter reads 5.1 VDC, or even better 5.2 as there will be a slight voltage drop between the power supply and the game board which will be approx 5.1 VDC by the time all the components on the board receive the power.
If you don't have a digital multimeter or are not too sure about the wiring at the power supply, you can go into the boot game into the test settings menu which will display the current voltage the board is receiving on the screen. You can then make the adjustments as necessary. Refer to the manual for details on how to boot into the test screen.
Hope this helps.
Posted on Oct 03, 2014
    New Friend:
    Problem Solver:
  • 15 Answers
Not sure of the generation of Golden Tee, but I recall the opto encoder on the trac ball causing this same problem. That being memory of years and years ago when I was a tech for a national distributor.
Posted on Dec 19, 2014
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
What is a driver golf club?
It is the club used to hit the golf ball when it is still on the tee.
Feb 04, 2013 | Golf
I can't get the right tv to game connection for plug and play golden tee live
Hi, i dont have this game but I recommend searching up instructions on google. The company who make this game would probably have instructions on their websites. Hope this helps
Dec 24, 2012 | Radica Golden Tee Golf Plug And Play Home...
Picture on golden tee is dark red not normal green did revert to green but back to red
Sounds like a cold solder joint. Unless you have knowledge of electronics and high voltage, I wouldn't try to fix it myself. A honest TV repairman should be able to fix it. And when I mean high voltage, I mean 2000-3000 volts is average with a CRT TV tube.
Dec 17, 2012 | Arcade Golden Tee Unplugged Video Cabinet
I have a 2005 golden tee tournament edition, when i turn it on it powers up but the screen is blank, any suggestions???
First you will need to open your game arcade machine and check the Game Motherboard cables and connections, check all plugs, every connector, reconnect all of them..and try to turn it on again!
After doing this try to check your power supply and see if it is working well..
see if the board look´s like this:
Note that some versions has ide hdd interface.
to help you, i find the service manual with all the instructions in this link
There is a step by step guide to fix your Golden tee!
Good Luck!
Dec 07, 2010 | Arcade Golden Tee Unplugged Video Cabinet
More height off the tee required and ball flight to the left
If you are using an iron club...never place the tee high...the higher the tee with an iron, the more draw or fade you will get. Keep the tees closer to the ground and take your stance back a little too...
Mar 16, 2010 | Taylor Instruments Taylor Made R7 Quad 9.5...
Arcade Golden Tee Unplugged Video  Cabinet Logo
776 people viewed this question
Top Arcade Video Game Consoles & Games Experts
Dan Webster
Dan Webster
Michael Vincent Cruz
Are you an Arcade Video Game Console and Game Expert? Answer questions, earn points and help others
