Question about Maytag MAH8700A Front Load Washer
The display is EE. the top line of the first E is not dissplayed.
Water is standing around the machine. The water is not coming from any of the hoses that are visable from the outside of the machine. I am not sure if the code is right or the LED is out for the top line of the first E.
Is it draining at all? My whirlpool threw a fault code today and it wasnt draining. I had to remove the front cover (at the bottom) there were 3 screws. I got a large heavy duty trash bag, stuck the top end under the washer, got my shopvac and then slowly turned the cover on the filter head. The water came out, I sucked as much as possible into the shop vac, the rest was captured in the plastic bag. When the water all drained, I pulled out the filter to find that it was full of lint from the chenille throw I had washed last nite. I cleaned it out, made sure the hoses were clear, and replaced the filter and the cover. It now works fine, and am doing my load right now. Good luck with your problem! Believe me, it stinks to have to play fixit on Mother's day!
Posted on May 09, 2010
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
Something must be clogged because the water wont flow into the machine and sprays around the top of the hose end at the washer. I checked the little filter under the hose and its clean.
There should be lights blinking, indicating a fault.
If this unit is brand new call warranty service.
If this unit has run in the past you will need either a new intake valve or new computer sequencer board.
Dec 04, 2012 | Haier HLP21E Top Load Washer
The washer smells funny. Like mildew or something. No water standing. Seems to drain.
Probably has some standing water in the pump hoses as well as the drain hoses If you do not use the machine often, then some water is left in the drain hoses and upon evaporation it may do what you smell. Pour some bleach in the tub, with water and let stand for 15 min. put it on rinse and let drain and do the smell test again.
Jan 09, 2011 | Whirlpool WTW5300SQ Top Load Washer
IN THE WASH CYCLE THE TUB FILLS ALMOST TO THE TOP THE DRAINS. THE OL CODE THE APPEARS AT THE END OF THE CYCLE
Hi, the OL code means Overloaded..
OL flashes when the machine/motor control detects a load size that exceeds the washer's capacity.Open the door lid to clear display, remove excess laundry, then restart the cycle.
Oct 04, 2010 | Whirlpool WTW6400SW Cabrio Washer
Update on Neptune TL extraction problem
Mike,
No problem just will help me and other linked to on going troubleshooting efforts. I did the same thing when I started.
I was logged in under my other forum name dh1200s any way this statement ""They should be stiff to rotate thru the transmission gearing but will move."" is wrong I can't rotate the tumblers by hand but check for that free wheeling tumbler. I'll add a comment about your request ""Is there a way to test the tumbler speed or to run the machine with the door open to see if they are spinning?"" Yes do you have the Service Manual?
Here it is;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Look in the SM it will show you how to raise the washer top from the base. Just make sure the washer is not signaling for water fill or you spray some water around. I’m going to post this under my FAV6800AWDIY forum name.
If you feel the need to tear down the drain line system here are a couple of pics to start ya off. Make sure when you remove the drain line from the Sump Cap on reinstall is snug up against the Sump Cap. To remove the Sump Cap to empty a coin or two and other possible debris it will twist CW to remove. When you reinstall watch you don’t pinch the rubber O-Ring. Place some towels under the Sump Cap to catch excess water.
Sump Cap and some stuff I found in mine but I had no wet clothes issue just doing DIY maintenance.
My Solution to preventing Drain Line clogs and broken Drain Pump impeller.
Better shot of the Drain Pump lay out and exit hose. I was doing a Outer Tub Bearing replacement. It will be a tight work area. That's why I came up with the Sump Cap filter screen.
Good Luck with you project and I will try to help if I can....Rich
Apr 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
KENMORE 70 SERIES KEEPS FILLING UP
you have a drain hose problem the water is shiphoning out as fast as it comes in you need to raise the drain hose above the tub level
Mar 15, 2008 | Kenmore 15864/15862 Top Load Washer
LG Dishwasher
ok. our machine has done this for 6 months or so, it was ok for the 1st 6 months. i have checked and cleaned and unblocked and gone bloody crazy. today i found the fault and fixed quickly.
the installer stuffed up. the waster water hose must head up and be fixed just under your bench top, then come down hill to your exit/spiggot/drain attachment.
ours was just lying more or less at floor level coming up to the spiggot. so whenever the waste water pump switched off, water would run back into the machine, hence the OE error, and also dirty water with food would then get chucked around it what should have been a clean rinse.
a diagram of the waste water house and how it should be done is in the manual.
i just about blew $1500 on a new machine !!
Jan 17, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
PF display on my maytag neptune
Hi liz PF on display means Power Failure...One of the components powering the machine is damaged...Do u know how to use a voltmeter?Do you have some knowledge abt electricals?IF YES report back..If not call a technician..You will need to check the power circuits around the motor section to see whats wrong..
Nov 03, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Water leaks during rinse cycle
MAKE SURE TO FLUSH-OUT DRAIN LINE. WATER IF IT IS DRAINING TO SLOW WILL START LEAKING AROUND THE LOWER PART OF THE WASHER WHERE THERE IS A SAFTEY OVER FLOW ... IF YOURS IS A FREE STANDING TOP LOADER THE DRAIN HOSE IS IETHER SEPERATE OR FLOWS WITH A CHECK VALVE THAT HOOHS RIGHT TO YOUR FAUCET. MAKE SURE THE CHECK VALVE AT THE FAUCET CONNECTION IS FREE AND NOT STUCK.
May 07, 2007 | Kenmore Elite 20972
Maytag MAH8700A Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
