Question about Dell Dimension E510 PC Desktop
I need to reset a bios passwoerd on my dell dinention e510 desktop
  • 88 Answers
There are 2 methods doing that (I assume you forgot this password).
1. Hardware (easiest one):
a. Switch off power (plug out power cable or switch off power supply)
b. open your PC box
c. locate CMOS battery on motherboard (the largest part)
it will look exactly like that (round)
d. Just take it out and wait 30 seconds
e. plug it in. BIOS data will reset (password as well)
#2. Sofware
You may use !BIOS to reset bios password. Download + instructions you will find on this website.
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
My computer stays on bios revision
If you feel comfortable doing it, open the case and remove the BIOS battery which looks something like this:
wait a little, then put it back and try turning on machine. Please note that you will loose all BIOS settings and you will have to reconfigure it.
Jun 17, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
I could not start my PC, a Dell Dimension E510. I got the message " Loading PBR for description 2 ...done
This is an error code that means Problem Booting Response hold down your Ctrl+Alt+Delete and see if it does not reset the boot series. it means a corrupt boot code you can try and use F2 to try to get into Bios and then f12 to get to the hard drive reboot option.
Jun 07, 2012 | Dell DimensionTM E520 PC Desktop
Bios passwoerd forgatten
When you forget the bios password the only one way to reset the bios password is to reset the jumpers on the motherboard.
For that you will have to open your system, and the jumper is located on the motherboard you need to reseat that.
That will take your bios to default and will fix your problem.
Sep 25, 2010 | HP Compaq 6535b Notebook PC KR995UAABA-
Dell Dimension E510 DVD Burner
Try to use cd cleaner to clean the lens, if this doesnot work, this means your lens is died, change the DVD Rom.
Thanks for using Fixya
Oct 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
When my dell e510 boots and gets past the first bios screen and shows it booting up the system components it is completely unreadable all letters are in the wrong place or distorted and the entire screen...
Sounds like it could be a graphics card problem problem is it's integrated so part of your motherboard unless you have installed a graphics card.If you have a graphics card in it take it out plug your monitor into the other graphics port and enable on board graphics in your BIOS/ integrated peripherals by pressing F12 key,..if it now works you know your graphics card is broke.If you havn't a graphics cardin it your motherboard needs replacing.
Aug 04, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Want power pins on the motherboard of a dell dimension E510
Hi, i think u need to talk to dell support chat, they will give you more info, or else try them in parallel, i mean like terminate with a screw driver or u can download the service manual for this like Dimension E510.
Hope that helps
Cheers
Apr 27, 2009 | Dell Dimension E510 PC Desktop
Bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Jan 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell E510 Freezes during Bios Load
u haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Jan 18, 2009 | Dell Dimension E510 PC Desktop
I update my bios in my dell e510 now all it does is restart over and over.
try to download the bios and flash it once again. still if u see the issue probably it could be a improper bios flashing. replace the motherboard
Jan 12, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Microphone and audio jack not working on dimension e510
look in the sound settings you may find the front panel audio and headphone have been deactivated, or try to re-install the sound drivers again, if there is any on-board audio, go into the bios settings and dissable it
good luck
Nov 17, 2008 | Dell Dimension E510 PC Desktop
Dell Dimension E510 PC Desktop Logo
212 people viewed this question
Alun Cox
