Ravenheat 82e lights the pilot but not the main burner plus the igniter keeps going even with the pilot lit then stops after 30 seconds
  • 2 more comments
  • Mark Peters
    Mark Peters May 09, 2010
    yes the pilot goes out after 30 seconds. I have to switch off the boiler for about 20 seconds and then i can try again but still get the same problem
  • Mark Peters
  • Mark Peters
    It's as though the boiler thinks the pilot is not lit. i cant find the flame sensor as shown in the book unless it is part of the igniter electrode
  • Brian Niten May 11, 2010
    Does the pilot go out after the 30 secs.
  • 674 Answers
Yes, it's possible that it is part of the electrode. You might try cleaning it with some steelwool.
Posted on May 09, 2010
  • Brian Niten May 09, 2010
    Also can you send a picture of the electrode or schematic?
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
I have a Model CGN250TE.The pilot light stays lit but when you turn control valve on it stays lit for 5 seconds and then shuts right down,even the pilot light goes out.I have tried venting the room and...
I would first check the gas pressure to your furnace. Then make sure that burners are clean and watch flames when burner first ignites. I have seen burners that were dirty cause delayed ignition that would create a suction when they came on and extingush pilot and burners.
The next thing I would do is change gas valve. Thank you
Dec 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
PILOT LIGHT KEEPS GOING OUT.
If the pilot flame is weak, when the main burner is ignited, there can be enough 'whoosh' of air and gas to blow out the pilot. There may be a little of grit in the pilot valve jet hole restricting the flow, hence the weak flame. Try using a piece of fine wire to clear the obstruction. If that does not help the pilot jet will have to be unscrewed and cleaned with compressed air. Ensure the gas is turned off before attempting any maintenance.
Sep 13, 2010 | Reliance Water Heater #6-40-GBRS 40GAL...
Pilot light keeps going out
Either the pilot light orfice is dirty, and you will need to pull it out and clean it, or the thermocouple is bad. If the pilot goes out as soon as you let the button go then it is most likely the thermocouple. If the pilot stays lit for a few days or hours then you will need to clean the pilot orfice, heres how:
1 turn off the gas supply
2 unhook the main burner gas line from the thermostat, this is the line that goes to the burner
3 unhook the pilot supply line it is usually next to the main burner line
4 unhook the thermocouple from the thermostat
5 remove the burner assembly
6 take the orfice out of the pilot line and clean it out by blowing thru it, use an air compressor if needed.
7 reassemble and light pilot
Apr 08, 2010 | Reliance & 30 Gal LP Gas Water Heater
How do I light my pottertn kingfisher pilot as its gone out? Keep pusing the ignite button but nothing is happening
Push also the gas button and hold in until pilot lit and then for some seconds [8-30] after until the thermocouple is hot enough to tell the boiler to light the main burner
Dec 16, 2009 | Stiebel Eltron DHC Instant Tankless...
My Ravenheat LS80 won't give me hot water!
years after the problem..... i find this link. relevant for future people i suppose and definately better than the previous answer which is not applicable at allravenheat.co.uk/pdf/manuals/LS80printV3.1.pdf
Apr 11, 2009 | Water Heaters
Heater goes out after 10 to 30 seconds.
sounds like a blocked pilot when you turn on the main gas takes the gas away from the pilot and goes out
Nov 08, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
