Question about Carrier Heating & Cooling
Wall unit leaking water - Carrier Heating & Cooling
  • 306 Answers
That is normal except should go outside. Tilt the unit away from the house a little only about 5 degrees should be good.
Posted on May 09, 2010
Why won't the water come out of the in-door water dispenser? Why won't my ice maker make ice?
Be thoughtful of any water leaks. Water leaking beneath the machine will damage floors.
If both the ice maker and water dispenser are not working it is likely the feed connection from the wall to the unit. The hose/ copper tube can get kinked or the valve at the connection at the wall internally plugged. Close off the water at the wall and using a catch remove the connection at the unit open the valve at the wall and confirm the that water flows freely through.
Check the filter of the water located usually at the front grill near the floor. If the filter is removed the water connection will buipass the filter.
It is not likely with both the ice maker and water dispensor that both electrical solenoid valves have failed.
26159659-bocfglvi4lojepqiax35xhd0-1-5.jpg Hope this helps?
Apr 10, 2016 | Kenmore Refrigerators
Aqualisa aquastream - when I turn it on the water pours down the wall. When turned off no trickle or leaks.
Surely something is leaking. I am attaching a diagram of the parts inside the unit for your reference. See if you can access the parts to find out which one is leaking and replace the broken part.
Feb 16, 2014 | Home
Wall unit is leaking water
Hello, if this is a window unit water will leak for one of two reasons, either a blocked drain or the unit is not tilted back enough in the window.
Jul 01, 2012 | Fedders A3X05F2A Air Conditioner
Water leaks from the wall unit after it works on a cooling cycle for a short time. Seems there is no provision for the water to be piped away. The wall unit is situated on a dividing wall between two...
That unit was not designed to be installed on an "interior" dividing wall between two rooms. Only on an exterior wall. There in lies the problem.
Feb 03, 2011 | Heating & Cooling
Drainage occurs near the front of the unit, resulting in pools of water leaking onto my window sill. Unit is installed properly, there is no drain hole to direct water away from the insides of the walls...
The A/C unit should be tilted slightly to the rear and this will allow the water to leak to the outside of the window, you may have to drill a small hole in the case to drain if there is no pre-existing hole.
Aug 15, 2010 | Frigidaire FAC126P1 wall/window Air...
Water leaking from indoor unit against the wall.
It's probably the insulation around your refrigerant pipes. If it is too thin or missing in a section they will condensate.
Jan 16, 2010 | GE Quiet-Aire Ductless Split System Air...
Water leaking into room
Angle your unit so the back is lower than the front and the water will run out the drain hole on the bottom.
Sep 02, 2009 | GE Heating & Cooling
Wall a/c is leaking water down log wall and puddling on floor.
When you sealed the holes outside, you trapped the water inside. The unit is designed to let the water run to the bottom of the pan and then go out the holes outside. Try unplugging one of them and see if that fixes the problem. Hope this helps.
Jun 24, 2009 | Emerson Heating & Cooling
Inside air unit is unlevel. leaking water. how do I level it?
wall brackets and cheeck the drain under the outdoor unit botton of unit.
Jun 03, 2009 | Heating & Cooling
Mitsubishi Air Conditioner FDKN Series leaks water after 30 mins
It could be one of two things -
1) The unit is not hanging level (assuming this is a wall mount, through the wall, or window unit), or
2) The condensate drain or trough to the drain is plugged/clogged/filled with trash.
Jan 22, 2009 | Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
