Question about LG 24 in. LDF7810 Built-in Dishwasher
PF indication I get an intermittant PF indication and the wash cycle stalls and machine beeps
  • 2 more comments
  • Anonymous Jun 03, 2008
    Same problem for the past 4 months - countless back and forth between qualified electricians and LG all pointing fingers at each other. LG refuse to take accountability for their shoddy products. I will never do business with them again.
  • ljbdreams Jun 25, 2008
    dishwasher starts normally, then 2 minutes if that it beeps and stalks. the led display area show LE. Restart procedures and the problem repeats itself.
    Is there a solution the owner can do without calling a very expensive repairman. thanks
  • Anonymous Nov 22, 2008
    After 2 min LE indicator appears and operation stops.
  • Anonymous Mar 14, 2009
    I've had this same problem....it's ridiculous.
  • 489 Answers
You are having a power issue with the plug outlet or the junction box at the bottom right of the dishwasher.  To be sure, run an extension cord and use a different outlet in the kitchen.  If after a couple of loads, the PF problem doesn't come back, have the outlet checked.  If it does, you will need a qualified LG tech to come out and see what's going on.
Posted on May 02, 2008
Why would machine throw a PF error code in spin cycle?
The PF error code indicates "power failure" condition. The fact that it was indicating on the display while fully loaded tells me that you have a bad electrical connection somewhere on the machines PC boards or supply.
The spin cycle is also triggering this condition when the vibration on the machine shakes the "bad" connection and causes a brief loss of power to the machine.
Sep 19, 2015 | LG SteamWasher Series WM2650HWA
Constant beeping while washing
This can be due to fault within the control panel output to the indication and buzzer. If the washer works without any issue and the cycles are correct, then it is best to remove the buzzer connections as the drive output transistor or IC could be intermittent and so works erratic.
Jul 03, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
Error PF
This indicates a POWER FAILURE which can be intermittent during the cycle thus causing a malfunction - the processor hanging up.
please check this link:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6333
Sep 13, 2011 | LG WD-1280FHD Front Load Washer
I get a PF error. That goes away and shows 52 in the display. The buttons light up, but pressing any buttons does nothing but to make 3 beeps.
PF is Power Fail, means the Power was cut off. PF Power failure Power to the machine has been lost during the last cycle. This may occur on start up of a new machine due to factory testing.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer stops washing and gives a p5 trouble code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
LG WM1814CW Front load washer PF continues to come on and stops cycle
Seen This before Main control board fixed it It would go through most of the wash cycle and just quit no errors but PF
Jan 29, 2008 | LG WM1814CW Front Load Washer
Dishwashers Logo
161 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
