Question about Frigidaire GLEQ2152ES Electric Dryer
No power The drum was making noise then it lost power all together.
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
drt312
Posted on Sep 30, 2010
I took apart my dryer to investigate a noise. While it was apart I noticed arcing at the terminals. L1 had completely melted. I purchased a new terminal block and installed it. Everything went back...
Hi herbert hurt...
The noise you are hearing could be your drum rollers.
They could need cleaning and lubrication or replacement.
If they need lubrication they will make a squeeling noise, if they have flat spots on them they will make a thumping type of noise.
If that is you noise then take the dryer apart and lube,clean, or replace the drum rollers
Please take time to rate me
Aug 17, 2011 | Vacuums
We were giving a maytag dryer Mod# MDET236 it was making a loud knocking noise so we opened it up and found a pocket knife and some coins after puting it back together it is still making the same loud...
First thing would be to make sure there wasn't something else in the drum. Next, it is possible that one of the rollers the drum rolls on could have a flat spot. This will require opening the case of the machine and getting a look at those rollers.
Mar 04, 2011 | Maytag Dryers
Overload affected performance. Even when only got 1 item in machine. Makes lots noise when spinning and inner large plastic seal looks like something caught on it and shredded some of plastic.
this fault can be caused by the drum halves becoming tight .they move together due to limescale deposits between the drum spiders. the noise is most likely a failing drum bearing
if the plastic seal is damaged then it will need a new drum assembly
they are no longer available from dyson due to supply problems
you may be able to get another machine from ebay and fix yours using parts from each machine to make one good one
Nov 10, 2010 | Dyson CRO1 Front Load Washer
I changed the belt on my Creda tumble dryer. Now its making noise
You may have to change the Guide wheel that the drum needs to rotate on
Sep 06, 2017 | Dryers
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
May 23, 2009 | Frigidaire FDE647RF Dryer
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Jan 04, 2009 | GE DBXR463EBWW Electric Dryer
Banging noise
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Apr 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
