Question about Filter Queen Majestic Canister Vacuum
Filter queen majestic vacuum
Help. First time using this hand-me-down machine. Middle of cleaning, opened it to check on filter. Shock! All dirt not IN filter, but around it in the base. IS this right? Should the filter not be containing all the dirt?
The filter is clean, and seems only to be protecting the white cone (attached to upper portion of this vacuum cleaner), not sucking the dirt into itself, but outside itself.
Please help. AM in middle of major cleanup here....
  • bpbp Mar 28, 2008
    Thank you so much for trying to help me. Regretfully, the illustration is too small for me to distinguish numbers (even using a magnifying glass on the screen), nor do I see my problem in it.
    And to complicate matters further, a different respondent says this particular brand of vacuum actually collects dirt outside of the filter, in the vacuum's base, not into the filter. Which would make sense in that there is no possible way to insert that filter without blocking the opening from the hose into the base. The filter covers this, and there is no way to avoid it. The tabs have no bearing. They just hold the filter in place, blocking the hose input hole into the base.
    So I am now confused....
  • 3 Answers
Common mistake when using a filter queen. i know, it freaked me out first time i looked inside too. filter queens have the motor on the top with the filter over the cone shape and the dirt collects in the bottom.
what you don't want to see is dirt between the filter and the motor ( top ), like i saw in mine today ! one of the tabs let go and let the dirt past the filter into the motor area. apparently there is a second filter ( flat disk filter ) that acts as a secondary filter. so now i have to find one of these and change both.
the reason i opened it up was that the top motor section was getting very hot and that didn't seem right, then i discovered the problem.
you can go to the fitler queen website and download the pdf manual.
i prefer other vacuums that use the buckets that you can dump out and reuse but the filtration on the 'filthy queen' is top notch.
so get some new filters and keep using it until it dies !
Posted on Mar 07, 2009
The dirt should be in the tank on the outside of the filter. the filter acts as the barrier between the motor and the clean exausted air. the only side that should be dirty on the filter is the side that is facing the inside of the tank. filter queens are wonderful machines. even the old ones work just as good as the new ones. your filter queen is working properly just make sure you change the filters once a month and the disk filter inside every 6 months. never operate it without the celluliose filter in place
Posted on Jul 11, 2008
The dirt is suppose to collect in the Canister. Your vacuum works on Centrifugal force which forces the dirt to the sides and the bottom of the canister. This allows the air to flow freely through the filter thus maintaining its cleaning power. If the Filter Collected dirt like regular vacuums it would lose power and you would not be able to pick up all the dirt. The diagram above has nothing to do with what you are talking about. It just shows the top of the machine broken down and has nothing to do with your original issue. I hope this gives you a better understanding of how your product works. If not call your local Filter Queen office and they will send someone out to explain it to you.
Posted on Apr 25, 2008
    President:
  • 1,673 Answers
The cone filter if put on right should collect the dirt, the tabs shoud be on the edge so when you put the top on, it keeps it in place. Wish I could help more, guess I would have to see it to figure it out. Here is a pic. of the top part, are all filters ok? There is one under the round card-board besides the one at the bottom of the motor. #18 is the filter.
Posted on Mar 28, 2008
  • Lauren Junge
    Lauren Junge Mar 28, 2008
    Sorry, after rethinking, the dirt does go into the tank and the cone filter is just a filter to help keep dirt out of the motor. Most mail programs have a zoom feature, yours must not or you could have enlarged that image.
Beater bar makes excessive noise
Mine was making loud noises too. ratcheting sound. Probably the beater bar has dirt and garbage. I was told to take it out and give it a good cleaning, and check the belt too. I know I had a clog in the upper part of the power. It seemed to help for a short time.
Oct 28, 2015 | Filter Queen Majestic Canister Vacuum
When vacuuming, dirt goes directly into canister not through filter help!!
The purpose of the filter is to prevent dirt from getting to the motor. The dirt is supposed to go into the canister.
Jan 28, 2011 | Filter Queen Majestic Canister Vacuum
How often is it necessary to change the filter one on a Filter Queen Majestic?
The best thing to do to both, keep your Majestic suction and air flow strongest, and keep from pulling dirt & dust from being pulled past the filters which can cause damage to the motor, and charcoal filter, replace the filter once a month. If you use it longer than that it will both loose suction and will cause your Medipure or Enviropure "charcoal" filters to wear out prematurely. Mark the change date right on the filter or on your calendar to help keep track.
Dec 20, 2010 | Filter Queen Majestic Canister Vacuum
We were told we can add water to the canister instead of using a paper filter. Is there a manual that shows the operation of the Majestic Filter Queen 95x?
This is a DRY vacuum only. Do not put any type of water in your vacuum unless you are cleaning the dirt container only.
Adding water to this machine will cause it to **** the water straight up through the motor and well, water and electricity do not mix.
Nov 11, 2010 | Filter Queen Majestic Canister Vacuum
I got a used filter queen majestic vacuum at a yard sale and want to fix it up and start with new filters where do i get the filters and how do i change them
Well you bought a really great vacuum cleaner. The Filter Queen's are extremely durable and very well made vacuums. They sell brand new for over $2500, so picking one up at a yard sale was a great find by you.
There are several different filters on this model that need to be replaced. Here's a link to a 6 month supply kit that we sell, which contains all the filters needed for a 6 month period:
Filter Queen MediPure Filters 6 month supply
The only other part that you should be replaced on a regular basis is the belt (only if the vacuum has a motorized power nozzle for cleaning carpets). The belt should be changed every 6 months or so. Even if it doesn't break, these belts will stretch out and not work as well as a new belt would. Here's a link to the belt that will fit your Filter Queen Majestic:
Filter Queen Power Nozzle Belt to Fit All Majestic models using a flat belt
Here's a link to the owner’s manual for a newer Majestic model. This is the only one that is available online. Even though it's a newer model, the maintenance and care will be exactly the same for your model.
Filter Queen Majestic Owner’s Manual
I really hope this was the information that you needed. If you have any follow up questions, please don't hesitate to ask them by using the comment box here on the Fixya repair page.
If this did help you, please be so kind and rate my repair helpful, or leave some feedback for me. This is greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
Jun 15, 2010 | Filter Queen Majestic Canister Vacuum
I'm lookinf for a owners manual for a 70th anniversary Filter Queen Majestic canister vaccuum. My sister in laws mother died and I bought it from her but she can find the manual.
Hi There,
Here's a link to the owners manual for your Filter Queen Majestic:
http://www.filterqueen.com/pdf/majestic.pdf
This may be a little newer model, however this instructions and use of this machine will be identical to the one that you have. They really have changed anything on their machines other then the looks of them for a decades.
Hope this helped! Please be sure to rate my repair helpful, or leave feedback if this answered your questions.
Chris Jones
GoVacuum.com
Apr 26, 2010 | Filter Queen Majestic Canister Vacuum
I'm not really a technician, but I used to sell Filter Queens and was taught how to maintain them, and have tackled "fixing" some problems. I am a 71 year old great-grandmother of 8, but have good health...
i just took my old majestic apart to fix the motor
on mine, when you open the top of the machine where the exit hook up is
you take out those three screws
the top case comes off and you can get to those three screws and alot more of the motor as well
Good Luck !
Feb 25, 2009 | Filter Queen Majestic Canister Vacuum
Need Filter Queen Majestic Owners Manual
I downloaded and printed a Filter Queen Owners Manual from the Filter Queen.Com website. It was hard to locate on their website, but I printed it free.
Dec 01, 2008 | Filter Queen Majestic Canister Vacuum
Replacing filter
usually, under the metal cone(the part the filter fits on) has a screw in the bottom. should remove and replace secondary filter to restore power.
Mar 27, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen, carpet attachment problem???
Open it up and see if the dirt inlet is clogged. It would be by the brush roll. But you must have a clog.
Mar 09, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
793 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
