Question about Vidal Sassoon Health & Beauty
NEED USER INSTRUCTIONS FOR VIDAL SASSOON VC331 HYDRATION STEAM ROLLERS
AS ABOVE
SOURCE:
  • 13 Answers
SOURCE: Replacement Blades
I dont believe you can get replacement heads for non-professional clippers. If you are going to invest in a new pair you could go to Sally's Beauty Supply and purchase a pair that you could always get a replacement head for.
If you dont want to invest in a new pair you could bring that pair in there and see if any of the replacement heads they have may fit. There is usually eather 2 or 4 screws that will go in there. You could find one that looks the same and it may just work! Good Luck!
Posted on Jan 09, 2009
SOURCE: Where can I find replacement styling attachments
I found a telephone number for consumer assistance.  Thanks, but I don't need you to go any further.
Posted on Jun 23, 2009
  • 10406 Answers
SOURCE: Could you please tell me where i can purchase
Look in the "Yellow Pages" of your local telephone directory for a "Shaver Shop".
Posted on Mar 03, 2010
SOURCE: i need a wide tooth comb for vidal sassoon 1875
i can not rechage
Posted on Mar 06, 2010
joninla
  • 34 Answers
SOURCE: vidal sassoon model vs2085a streightners, red
I have found that current devices that heat up (hair dryers, straighteners etc...) all are made so flimsy that at a certain heat point, the shut off.
I also have come to realize and expect that there IS A SHORT LIFE EXPECTANCY for any heating electrical product.
If your device is new, I would return it. If it's old, buy a new inexpensive one (on sale) .... MAKE SURE YOU BUY ONE THAT YOU KNOW IS GOING TO HAVE A RELATIVELY SHORT LIFESPAN. Silver color does not mean metal nor a longer lifespan. Buy cheap, use and replace as needed.
It's an eco-nightmare, but once a heating product goes out, it is too dangerous to even think you can fix it yourself without risk of potential major fire. It may look fixed and you then come home and it's burned to the ground.
Be careful and wise.
Posted on Jun 15, 2010
Looking for a replacement bulb for a vidal Sassoon make up mirror
There is nothing online to give a clue as to the replacement.
Take the old one out and look on the glass or the base for voltage and wattage.
replacement bulb for vidal Sassoon makeup mirror Google Search
Aug 22, 2018 | Sassoon Health & Beauty
Vidal sassoon model vscl802 replacement parts
Fixya is unable to suggest sources for Vidal Sassoon parts.
Jun 15, 2018 | Sassoon Health & Beauty
Vidal sassoon vs505 disassemble
There is one Philips head screw near the top of the handle and there are four more behind the rubber on the handle grip. The rubber on the handle grip is attached to a curved plastic plate that has four clips that hold it to the handle, you have to pop the plate with the handgrip rubber off the handle to access the four screws.
Mar 23, 2014 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
How to dissassemble Vidal sassoon VSCL816. (e.g. scissors area). two phillips scresw unscrewed, but two shells of housing cannot be separated completely. Hint needed for taking away scissors. Scissors got...
I have a Vidal Sassoon Max hair clipper, and I suspect the construction of it is similar to yours. To take the two halves of the body shell apart you need to remove the blade assembly. Try this:
After removing the two visible screws, place your thumbs at each end of the cutting blades and push upwards.
The blade assembly should unclip, revealing two more screws underneath. Remove these, and the two halves of the body shell should come apart.
Graham
Apr 10, 2011 | Vidal Sassoon VSCL816 Beard Trimmer
Hi, i've recently been given some hair curlers - vidal sassoon VS 254 hair hydration - but the user guide is missing. Can you please advise how to use them, if water is needed, to be used on wet or dry...
Vidal Sassoon site pages lists products, each of which has a manual which may be downloaded. I can not identify your device but there is a wet dry straightener there and a large list of curling stylers, each with a manual. Here is a sample:
Wet Dry Style Straightener
Here is the site map:
VS Sassoon Australia
I have yet to see the manual for the product you describe but perhaps one of these will be helpful.
Nov 27, 2017 | Health & Beauty
Replacement blade
GO ON LINE YOU SHOULD BE ABLE TO ORDER THEM FROM VIDAL SASSOON.
Mar 15, 2009 | Vidal Sassoon VSCL900T2 Hair Trimmer
Health & Beauty Logo
138 people viewed this question
Top Vidal Sassoon Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
