Question about Vacuums
It will run for a short time than just shut off
    Sergeant:
  • 144 Answers
If this is the case it is a motor problem due to weak coils, call the engineer to smooth in your work .
Kindly rate my help++++ Thank you
Posted on May 09, 2010
Vacuum runs for a while then shuts off and then after being off for a while it works for again for a short period of time.
Sounds like motor overheating, disassemble and clean electric motor.
press the helpful button
Jan 03, 2016 | Vacuums
How to find the battery dirt bd10085 ?
Hi! The battery on the BD10085 is located internally. It is not user accessible or replaceable. If you are experiencing a short run time try depleting the battery. Run the cleaner until it completely shuts off and re-charge for a full 24 hours. Good luck!! If you need more assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Aug 10, 2014 | Dirt Devil 9.6V Gator Hand Vac, BD10085
Change motor brushes on Fein vacuum
If the vaccuum was used with large amount of fine dust , most times the filters are largely shut beaten ,beware also of the electric field look its color to get a indication of the expectation of the remaining running time of the motor. 80% chance by use of fine dust the motor can better be replaced instead of replace brushes because the brushes are in a short time again shorted because of 1 collector in the armature , or get an equivalent motor if you can get FIXAPART motor or a original replacement if the remainder is still in reasonable condition.
Some brands of vaccuums uses the same motor could be sometimes an option because of the price.
Sep 07, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
Vacuum shots down after a short time, restarts but runs only a short time
yes that unit has 2 sensors 1 on the motor and 1 on the relay board 1 of them is bad which is making the vacuum shut its like a heat sensors its malfuctioning it shuts the unit down
Feb 17, 2011 | Broan-NuTone VX550 Bagged Central System...
While vacuuming, the unit will stop/shut down. A short time later the unit will operate again but not for much longer. All filters are clean/new.
Check your hose for a clog. It's likely there is a plug somehwere. Run it (not while vacuming the carpet) with all three filters removed. See if you get good suction. If not then look around for a plug of dirt and hair somewhere.
Jul 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
I have an easy flo vacuum model # 199C and it won't shut off. It started out as an intermitent problem but now will not shut off when the hose is unplugged, nor when the off/on switch on the main unit is...
Remove the low voltage wires (top left) if the vac unit still runs the problem is with vacuum
if the Vac stops running then there is problem with the low voltage wires in the home possible short some where in the system Chech the inlet doors first. Easy Flo vacuums have a lifetime warranty call 1800 easy Flo.
Feb 13, 2010 | Easy Flo EF1500 Vacuum
Our roomba vacuums, then beeps 5 times and shuts off.
Your cliff sensors aren't working properly. Tap the bumper five or six times to knock out anything caught behind it, then blow out under the bumper with some compressed air, really thoroughly. If that doesn't do it, call customer support at 877-855-8593.
Jul 04, 2009 | iRobot iRoomba 4000 Robotic Vacuum
Short run time
I turned mine over, and took out all the little tiny screws. There are 10 of them. Then 1 by 1 I took each gear out and cleaned the cat hair from around it, then put it back together. Mine works perfect now.
Be careful, I suggest disassembling one corner at a time and putting it back together as you go.
Good Luck
Feb 11, 2009 | As Seen On TV Swivel Sweeper Vacuum
I have a central vacuum system. When I disconnect the hose from a wall outlet the central canister does not shut down dispite my turning off the vacuum at the handle of the hose. The only way I can get...
What I'm hearing is the canister(Not the Powerhead) portion of the unit is running all the time unless you unplug it. this problem could be caused by a short in one of your low voltage lines running through the house. To determine that just unplug one/both low voltage lines from the canister, and plug it back into the recepticle. If it doesn't start up then you figured out that it is in the house somewhere and not the unit. If it is in the house I would check for water in the valves, or you're just gonna have to chase down the short. If the unit is still running with the low voltage wires disconnected then it is probably the relay on the board, which means you will need a new board unless you're expereinced at soldering and want give it a try replacing just the relay. Which you'll probably need a new board by the time you're done anyhow. LOL
Good Luck
Nov 21, 2008 | Vacuums
Temperature light keeps coming on
The whine tells you taht the bearings are bad. Now they may be putting a drag on the armature and causing it to shut down after getting hot. You will have to replace the motor.
Apr 16, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
