Amplifier moving spontaneously from one input to another cutting out used source
18 year old onkyo hifi stereo amplifier will not keep a single input channel. It switches from tape deck to Tv to Dvd player etc on its own. It does not seem to be linked to heat because it will go into its dance amoung the channels whether warm (having been in use) or cold (just when we turn it on). the result is that the sound comes and goes willy nilly.
  • filosopher Jun 16, 2008
    I tried upgrading to a Cambridge which seemed to have the necessary specs and it ended up in SMOKE!!! So now I do not even dare up grade. I have heavy duty TANNOY speakers and large wires to the amplifier.
  • 54 Answers
18years is good service you may want to look at upgrading to a newer model. If you have become close to this amp I think the processor for the amp is going bad and you would have to replace the entire board ,and on this old of set woud not be available.
GOD LUCK
BIG RED
Posted on Apr 02, 2008
SOURCE:
What is the wattage output of the kenwood ka 728 integrated amp?
Specifications Power output: 130 watts per channel into 8? (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.007%
Input sensitivity: 0.2mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 69dB (MC), 87dB (MM), 107dB (line)
Output: 150mV (line)
Dimensions: 340 x 109 x 369mm
Weight: 9.2kg
Year: 1984
Kenwood KA 828 Manual Stereo Integrated Amplifier HiFi Engine
Nov 15, 2016 | Kenwood Audio Players & Recorders
The source selector of my onkyo A 807 runs away
HI try this video it worked for me. :)
http://www.youtube.com/watch?v=0Xfm-9jCmjE
Apr 09, 2013 | Onkyo Integra Intergrated Stereo Amplifier...
How to connect UB1202 to an Amplifier
Hi ha07. Have you fixed your Problem? If not, If you are using a HiFi amp you can connect it to any AUX input or tape in.
But better to use Aux, so you can keep Tape-In free, but it all depends how you want to use your system for recording
From the Mains "OUT" of your Mixer, 1/4 inch to RCA lead/s or adaptors will be needed, (Depending on your AMP) into the aux input of your stereo. But their is many scenarios for inputs and outs.
then you can run a lead to your computer from your Mixer or amp from Tape out, but again lots of possibilities.
Hope this helps if you haven't fixed your problem
Dont use (Phono input)
RustyRecords
Good luck and Vinyl Rocks RustyRecords Mail
Jun 29, 2012 | Behringer UB1202 Eurorack UB1202 Mixer (12...
The amplifier after turn on after 5 seconds go to Video 1 and you can't change to other input, the amplifier don't do nothing if you turn off , the amplifier turn on againyou
The microprocessor may need to be reset. To do so, perform the following;
Unplug the unit from the power source. Wait for a few minutes and then plug it back in again.
Sources of the problem can be from radio interference for example, or I would suspect given the time of year you are reporting the problem, our Sun which is more of a rare incidence but peak times are during the same months as the appearance of the aurora borealis.
Other causes are static electricity.
Nov 29, 2011 | Onkyo TX-SR703 Receiver
I have an old integrated amplifier and an old BSR EQ-3000 stereo frequency equalizer. i just bought a used bose 901 speaker set. how do i hook-up the bose 901 equalizer in this system?
Hook the signal source to the equalizer input and the equalizer output signal to one of the signal inputs on your amp. This is one way, but this way only one signal source will go through the equalizer (unless it has several signal inputs and a source selector switch).
The other way (inserting the equalizer between the preamp and the main amp) is:
If your amp has RCA connectors on the back named "preamp out" (or similar) and "power amp in" (or similar) that have slugs connecting them, remove the slugs, hook the "preamp out" signals from the amplifier unit to the signal inputs on the equalizer and outputs from the equalizer to the "power amp in" inputs on the amplifier.
Basically, what you do is that you insert the equalizer between the preamplifier section and the power amp section of the integrated amplifier so that you can still select the signal source without having to switch any signal cables (however, i can't say if your amp has got this type of "slug" connection feature between the preamp and the power amp on the rear panel, so i'm not sure which way you'll have to hook it up).
Hope you can make it work the way you want.
regards
Triarcuate
Sep 30, 2009 | Bose 901 VI Main / Stereo Speaker
RCA input
Not possible to hook up a stereo signal to a mono and get a stereo signal back out.
Dec 26, 2008 | Audiovox AMP522A Car Audio Amplifier
How do I connect my bose 901 active equalizer to a onkyo tx-sr506
AV receivers are notoriously incompatable for Bose 901s. The problem is the EQ charges the entire system and could damage the surround processor. Some higher end AV receivers, including some of the newer Onkyo models have pre out power in inputs on main or all seven channels.which you could install your EQ directly between pre amp & power amp without damaging processor. You can also add a two-channel amplifier to the pre out jacks front channels and use your recever's remote to control volume.
Nov 30, 2008 | Bose 901 VI Main / Stereo Speaker
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
Onkyo integra a-809 amplifier
Use Deoxit on the switch. It is a contact cleaner available at Radio Shack and Fry's. Exercise the knob well. It worked for me on my newly acquired Onkyo A809.
Jan 13, 2008 | Onkyo TX-SR803 Receiver
 Grubhead
Grubhead
Marvin
Marvin
