Question about Sharp AR-M160 Black and White Copier
Error light h-4 ar161
Error light flashing H-4
  • 328 Answers
Press(# interrupt C interrupt)lcd will turn off.enter 14 and press copy key
Posted on May 30, 2010
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Tip
What to do to get your Whirlpool dishwasher to start when the light keeps...
<span>Hello,<br /><br />To reset the dishwasher push in this order the,<br /><br />HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF<br /><br />the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??<br /><br />example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4<br />7 flashes then pause then 7 flashes its displaying the error code#7 ect ect<br /><br /><br /><br />GENE</span>
on Sep 06, 2011 | Dishwashers
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f16 N/A
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
Sharp AR161 Copier Printer Problem
Reinstall your printer in to your computer and try the test print.
Feb 20, 2008 | Office Equipment & Supplies
Sharp AR-M160 Black and White Copier Logo
56 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
