Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
The strings that cut the grass fell out
They fell out of the black and decker grasshog
please help its mothers day and my mom is going to kill me if i dont fix it
How to wind string around the bobbin
The manual is available on line if you do not have your hard copy OR you could purchase a spool already loaded and ready to go.
Jul 01, 2010 | Black & Decker 14" Grass Hog Xp...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I need directions to replace string on black and decker cordless 18v grasshog
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jim
Jun 17, 2009 | Black & Decker 14" Grass Hog Xp...
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
514 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
