Question about Intel Motherboard
Error 115 upon bootup loading stops - Intel Motherboard
  • 61 Answers
Try replacing the CMOS battery (every motherboad has one).
Posted on May 15, 2010
Motherboard Error Code 62
first replace your ram,if problem occur,then check your c.p.u
Jan 26, 2014 | Biostar Computers & Internet
COF10 Error upon bootup
Circuit board under the big glass is bad, reset by open close front door. I dont known if you can find a circuit board if bad
Sep 07, 2011 | Minolta EP4000/5000 CS/PRO Copier
Disk error msg on bootup
Remove all the external peripharials from the system and restart it......it will work!
Jul 29, 2010 | ASUS Eee PC 1000H Laptop
I have a Goodman high-eff furnace, 115 BTU/hr. The fan runs constantly but it has stopped blowing warm air. I'm getting 6 flashing lights as error code. What's this mean?
Remove the lower panel and look for a wiring diagram pasted to it. On that diagram there will be an error code diagnostic chart. Depending upon which model you have it could be an open overheat switch caused by a dirty filter or a bad fuse.
Feb 13, 2010 | Goodman GMS90703BXA Heater
Upon startup i get an error: configFree has stopped working. I run the virus program Norton 360 but it says no virus. before this i was installing an application and it gave me the "you need to be the...
I would reinstall your operating system fresh after doing a full format, remember to back up your hard drive. I have never had satisfactory results from any virus scanner or system restore.
Oct 26, 2009 | Toshiba Satellite M45-S265 Notebook
Gateway laptop will not load windows anymore
eather the hard drive is bad or a windows program was removed. might need to reinstall windows.
Jul 07, 2009 | Gateway 450ROG Notebook
How do I fix a boot loop on my acer veriton m410
Try loading to Safe Mode (probably F8 or Delete key upon bootup). If unsuccessful, you probably will need to reinstall the operating system.
Jun 20, 2009 | Acer Veriton M410-UD4000C Athlon 64 X2...
Bootup
Ed,
Are you referring to the white underscore in the upper left corner of the monitor on bootup? It is very likely that a device driver is hanging on boot up.
To find out which one:
1. Upon restart, press F8 (several times) to force the Windows startup menu to load.
2. When the menu loads, select the option that allows you to manually confirm or deny the loading of each device driver.
3. When you have discovered which driver is not loading, perform another reboot, and do the step by step confirmation again, and say NO to that driver.
4. Finish loading windows, and correct the issue with the offending driver.
5. Reboot yet again, and allow windows to load normally.
Nov 03, 2008 | Audiovox Jensen NVX-3000PC 7 Windows XP...
EToshiba Satellite A100-S8111TD - Laptop do not finish boot on startup
Upon powering on, press the F8 button to load other options, choose safe mode only and hit enter.
If you were able boot windows under safe mode, you can try to do system restore or uninstall any program you've recently installed which cased the problem.
If you were NOT able to boot to safe mode, you need to do full system recovery and re install the OS. Insert the recovery disc and press F12 upon powering on to load boot menu then choose CD/DVD rom.
Hope this helps,
Sep 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Intel Motherboard Logo
266 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
