Question about Garden
I have a yardman model#11a-439q7551663710 5.5hp timming off
I have a yardman model#11a-439q7551663710 5.5hp 160cc 21in cut honda engine how do i adjust the timming on it
4 Suggested Answers
SOURCE: Troy Bilt model 542(11a-542-q711)has Honda 160cc
I need Gaskets for caboretor
Posted on Sep 08, 2009
  • 100 Answers
SOURCE: My Honda 160cc lawn mower
Has probably broken flywheel key ..... putting it out of time
Posted on Aug 14, 2010
  • 19 Answers
SOURCE: what type of oil do you use for 6.5 hp yardman
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
Posted on Oct 27, 2011
Runs rough, Uses LOTS of fuel, not leaking fuel, Starts hard.
turn your set screw at 1 1/4 turns from closed,it is wide open
Jul 19, 2015 | Garden
6hp yardman model 11a-503e755
you may have a air leak around your carb somewhere
Aug 20, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How to change the oil in my MTD 6.5h Honda yardman
Many mower engines no longer have a drain plug, or the plug is covered by the deck or other components, the best way is to suck the oil out via the oil filler, there are plenty of inexpensive vacume pumps availble that makes the job easy, check out the dealers or e bay.
Mar 14, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What type of oil do you use for 6.5 hp yardman lawn mower mtd 160cc 21 inch self propelled
Tim
Oct 06, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Son ran over some chain with my Troybilt mower with the HONDA 160CC OHC engine. Since then, the mower cuts off when it gets into higher grass. Problem getting worse , almost like something is loose?
check that the blade disc or carrier is tight and the woodruff key on the pto shaft has not shawn / sheared
check the flywheel key under the starter cup nut
could be sheard and is out of time or is moving when unit starts and stops
a shawn key will not stop it from sparking just wont spark @ correct time , check that pto is not bent
might pay to check camshaft timming as well and check timming belt
here is web site for parts breakdown
http://www.honda-engines-eu.com/en/welcome.html
go to service, spare parts , then select gcv160 from list
then hit search
a engine list will come up
cheers hope it helps
Aug 06, 2010 | Troy Garden
Starts but when chock goes off stops running Honda engine Yardman self propelled mower
OK take and check this. A lot of the honda engines,especially push mowers,tillers and pressure washers,they put a type of coating inside the gas tank. The bad thing about this type of coating is it has a tendency to peal and wash into the carb. I would look inside the tank to see if there is any debris. I would also clamp off the fuel line and take out the bolt that holds the fuel bowl on and catch the fuel that drains out in a clean tray. If it looks dirty,pull the carb and clean it,it should fix it.
Aug 09, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
