Question about StarTech.com StarView SV211K 2-port KVM Switch
Have a starview box lost a few channels so done a factory reset scanned all channels again now i can get back onto channels wont allow me to exit im stuck on the language page wont exit any idea,s ? many thanks
  • paulcarling May 09, 2010
    hello thanks for your reply what i meant is i cant exit the page im on, were u press exit it gives you the option to go back to channels?
  • 293 Answers
SOURCE: loss of starview channels
Try and determine the lowest transponder frequency that you can get a signal on.
Look at the frequencies you already have on the channels saved so far and choose the lowest.
Then in the installation menu select MANUAL SCAN and set that as the frequency.
Make sure you can see a signal and scroll down to Network scan and change to ENABLE with the Right arrow.
While still highlighted, click OK.
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? (the ?? being 2 digits).
Using this method indicated it scanned 56/56 transponder frequencies as opposed to 48 in Auto scan on one main provider.
Posted on Dec 11, 2008
ziraffa
  • 827 Answers
SOURCE: cannot get out of starview languages menu
You have to put the keys in manually, do as follows:
Press menu button
Press 1570 this takes you into secret menu.
Now hit ok on nagravision
Next make sure your cable provider is listed at top NTL or TELEWEST C&W ect
Now change key 00
(YOU MUST SAVE EACH KEY INDIVIDUALLY - I.E. AFTER CHANGING KEY 00 MAKE SURE
YOU STORE BEFORE CHANGING KEY 01 (TO STORE PRESS OK)
Here's the latest codes:
Here's a visual guide:
http://www.freewebs.com/boxsuper/
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
  • 19 Answers
SOURCE: lost all channels after factory reset
do a power scan m8 all channels will return
Posted on Mar 03, 2009
  • 54 Answers
SOURCE: lost channels
What I did after loads of trial & error trying t follow peoples advice on here so not sure how much of it you need t do (Stage 2) might not be neccessary so try 1) followed by 3) & 4) first ;o) :-
1) Deleted all the channels & reset the factory settings to 0000.
Turned off the box at the plug, left for a couple of minutes & turned back on
2) I reinstalled the software at http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess (Not sure if thats necessary but I did so try this if 3 & 4 dont work without reinstalling)
3) Turned on the Box & went into the menu pressed 1570 on main screen to get into the CAS SASTEM & turned the EMU key ON
4) Reinstalled the channels using Telewest (Even tho I'm with Virgin) & voila, it worked & I can get all the channels again ;o)
Good luck - Stace
Posted on Jun 20, 2009
thomas2397
  • 15 Answers
SOURCE: channels lost on starview box
Yeah i had the same problem with starview 4. i upgraded the firmware and still no good. i then by accident set the default key. it worked. i'm not sure if it will work for u.
Posted on Aug 30, 2009
I have lost a few asian channels on Starview
you are doing well to have any channels at all as all the other people have lost all sports and movies so i would delete the channels that are scrambled and then rescan you must delete the scrambled channels before you rescan
May 13, 2010 | StarTech.com StarView SV211K 2-port KVM...
Hello lost my starview box last night tryed the codes but no fix yet could someone please tell should i be on NTL or TW (Middlesbrough Area) many thanks in advance
ye just go to installation and manual scan then auto scan make sure ntl is selected 1st, channels might be mixed up but sort mannualy ,a pain just takes a bit of time
Feb 23, 2010 | StarTech.com StarView SV211K 2-port KVM...
Starview channels missing
you should not have factory reset when you lose a chnl delete the chnl then rescan you never need to factory reset you lose the flash or newest update you had installed reflash your box and delete the chnls that are scrambled only and then rescan
Feb 20, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Channels lost on starview box
Aug 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
Have a starview 4 the box super, is espn available os m screen is just blank?
yes, re scan for channels, when you find e***n go back to s** sports 1, press MENU- THEN 1570 THEN SCROLL DOWN TO KEY LOCK make sure you switch it on, then press exit good luck PS hope you do,nt live in ireland
Aug 24, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lost channels
Good luck - Stace
Jun 17, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Did power scan by mistake and now no channels
restore to factory defaults and than delete all the data ( all the channels ) once done . run power scan and your box should be up and running again..... :)
Jun 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
185 people viewed this question
Top StarTech.com Computers & Internet Experts
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
