Computer does not recognize usb memory stick - Computers & Internet
  • 416 Answers
You can try the USB on another PC to see if it's you PC thats having a issue or the USB drive. if the USB drive is still not reading or detecting, then i am afraid you are having a dead USB
Posted on May 09, 2010
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Memory stick does not open
Do you have a Sony memory Stick?
When you plug in usb drive does your computer recognize it?
If not the try a different usb port, then try on a different computer.
If it still is not recognized throw it away it is damaged.
Apr 09, 2014 | Electronics - Others
Memory stick storage format problem
Do it inside of My Computer, format it as NTFS
Mar 19, 2010 | Electronics - Others
WONT BE RECOGNIZED BY MY COMPUTER SIEMENS FUJITSU (WINDOWS XP SP3)
Try the device in some other USB port on your computer.
Try the device in some other computer.
Mar 03, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Compaq Presario S5200NX will not recognize memory stick
is either you reload the computer system or u buy an internal or external usb card.or check the connection cable inside the computer machine if it is properly connected
Jan 16, 2010 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Jun 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
I need help opening a file saved on my memory stick with my pc
IF the win98 box wont recognize the usb stick you will need to install the drivers in order for the OS to recognize the device, after this you should be able to see the device and files on it
Jan 22, 2009 | Computers & Internet
SanDisk Memory Stick Pro Duo problem
it may be lost, safely remove your hardware befor you get off from the computer
Nov 02, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
My windows 98 dell dimension 7500cx will not recognize my verbatim 256 mb memory stick
windows 98 need special driver from usb memory stick manufacturer.
if they dont have it then its not a compatible model for win 9x.
what i have done in prior is if high speed internet is saving it to online drive storage free website like xdrive.com if u have aim account youre ready to use it or others like yahoo mail yourself the files then retrieve in other pc.
Jul 30, 2008 | Electronics - Others
Psp
* Make sure you have inserted a memory stick, and enable the usb connection via settings=>usb connection
* Check the usb cable, or simply find another one to try if it works.
* If there is a memory stick inside the psp and the psp can recognize it, then you most probably have a problem with your cable or usb port.
* if there is a memory stick inside the psp and the psp cannot recognize it, as well as the computer, then you are most likely to have a failure with your memory card.
There are too many possibilities, maybe you can give me details straightaway, so more people can help you.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
Open Questions:
webroot TEC-H HELPline 1800445-2790 webroot Account Recovery Wizard fgfG Forgotten your webroot ID,webroot's Account Recovery Wizard page. Follow the step-by-step instructions to recover your account information. Reset a Forgotten Password (Partner Accounts) Use the Sign-in Helper to reset your webroot password and regain access to your account. For account security, webroot only displays some of the options. The system determines which options to display, based on factors like from where you're signing in and the your account's recovery settings. Change, Recover, or Reset Your webroot Password (Partner Accounts Only) If you have an email account with webroot through one of its partners (webroot, AT&T, Frontier, Rogers, BT, Sky, Spark, or MTS), follow these instructions to change or reset your password. Your webroot password gives you access to every webroot service that you use. You'll need to know your current password in order to change it to something else. If not, you can reset it to start fresh. In order to change your password using a mobile web browser, go to the webroot Account Info > Menu > Account Security > Change password. Enter and confirm your new password. Then, click Continue. A confirmation will appear. Click Continue to finish. Reset a Forgotten Password Use the Sign-in Helper to reset your webroot password and regain access to your account. For account security, webroot only displays some of the options. The webroot system determines which options to display based on factors like from where you're signing in, your account's recovery settings, your mobile phone number, and your alternate email address. Go to the Sign-in Helper. There, enter your phone number or email address, and click Continue. If prompted, enter the CAPTCHA code. If you can receive text messages to the number listed, click Yes, text me an Account Key. If you have access to the email address listed, click Yes, send me an Account Key. Depending on the option you've selected, webroot will send an Account Key to your phone or email. Enter the Account Key that webroot sent in the field provided, then click Verify. Select an account to reset from the list connected to your mobile number or email address, and click Continue. Recover webroot Password Using Your Secret Questions If, when you created your account, you registered secret questions, you will no longer be offered to used them to recover your account. webroot has done away with secret questions. Recover webroot Password Without Your Secret Questions As mentioned before, webroot has done away with secret questions. Instead, go to the Password Helper, and enter your email address. If you have a mobile number, listed on your account, the Password Helper will show it. If you don't, click No, I can't receive text.You'll see your alternate email address. If you have access to that email account, click Yes, email me. A "Recover access to your webroot account" email will be sent to your alternate email address. Enter the verification code that webroot sent to you in the email, then click Submit. Enter the code to access your account. Invalid ID or Password Message If your attempts to log in are being met with an Invalid ID or Invalid Password error message, this means that you've entered a password and webroot ID combination that doesn't match what's on record. If you're sure that you're entering the correct sign-in information, there are a few scenarios as to why this might be happening. If your password contains numbers or letters, make sure that your caps lock or number lock keys are activated or deactivated as needed. Case-sensitive passwords are often entered incorrectly due to key stroke sensitivity. Take a look at your browser's auto-fill settings. If your browser usually enters your password for you automatically, and you've changed your password recently, you'll need to enter your new password manually to override your browser settings. If you're sure that you're entering the correct information, this could be a sign that someone else has accessed your account and changed your password. You should change your password immediately using the Password Helper tool. Once you regain access to your account, review the steps to secure a hacked account to undo any changes made without your knowledge. Your Account Recovery Information is Incorrect or Has Changed
Jul 19, 2018 | Webroot Computers & Internet
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
