Vulcan ducted heating
we recently purchased a property with a Vulcan CX9021 furnace for the ducted heating. there were no instructions provided or left on the heater. Is it possible to obtain these?
Regards,
James
  • Anonymous Mar 17, 2014
    vulcan ducted heating 901 is not heating up. there is no spark when you first put it on to start up. Cannot find the problem
Heater lights up then turns off stays on for 2sec keeps on doing it
Posted on Jun 16, 2013
  • 86 Answers
Not possible
Posted on Mar 28, 2008
We have vulcan ducted heating. not much air comning from vents. what could be the problem
Could be simple as collapsed ducting, blocked return air filters, broken ducts, loose fan belt ( if belt driven unit)
Jun 06, 2017 | Vulcan Heating & Cooling
Can you install class-A cotton foil-backed insulation in a furnace heat exchanger duct
HVAC Insulation Cotton thermo acoustic duct wrap reduces noise and increases HVAC...
None of these products are used INSIDE the heat exchanger. If the problem is a cracked heat exchanger, you may be able tp purchase replacement parts to repair it
How to Fix Cracked Furnace Heat Exchanger DoItYourself com
The heat exchanger must be free of cracks and holes due to the potential of carbon monoxide leakage. You can probably make a short term repair with sheet metal and high heat furnace refractory cement, but that is a quick fix only.
Please be aware of the potential for a lethal situation due to carbon monoxide poisoning.
May 26, 2014 | Cozy (W352E) Heater
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
I recently had a ducted gas heating unit undergo a routine service. At the same time, the technician identified an external gas leak. The gas leak was subsequently fixed by another technician who noted...
The tech that fixed the gas leak had to shut the main gas supply off so if he didn't bled the line to the furnace you may still have air in the line....... Go ahead and shut the furnace off and retry to start it again it takes a couple of trys to bled the air out through the pilot.... And if that doesn't work I would call the first tech and have him recheck it......that is assuming that you have an electronic ignition type furnace.
Apr 19, 2011 | Heating & Cooling
My brand new, recently installed gas furnace is smoking a little out of the supply lines on the first trial run. Now I applied flex duct tape to all the openings to seal up the duct work for leaks, but I...
yes tape would burn there i would remove what you have put inside most when new will give off some smoke as the heat exchanger has some grease coatings on it just burn it off , if this does not stop call back person who fitted it
Nov 04, 2010 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Wiring diagram required
Just wondering if you h
Apr 19, 2009 | Washing Machines
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
1,367 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
