Question about Kenmore 63942 Dryer
I NEED OWNERS MANUAL TO KENMORE DRYER
MODEL # 110.60922990 THE DRUM WILL TURN, BUT NO HEAT. WE ARENT SURE WHERE EVERYTHING IS LOCATED AT TO FIX THE HEATING ELEMENT OR THERMOSTAT. PLEAS HELP IF YOU CAN. THANK YOU!!!
dryer doesnt get hot enough
  • rileygirl Mar 31, 2008
    I am having the same problem with the same dryer. I just took mine apart and found a loose yellow wire and I located the connector. I am afraid to just plug it in without looking at the schematic.
  • Jann English
    Jann English Oct 06, 2008
    okay. don't have a caps key so bear with me. i just need to know where the element and reset buttons are. my model is 110-96573230. help?
    President:
  • Kenmore Master
  • 2,651 Answers
Thiknin you need a service guide , not owners manual( only tell how to operate} ther is a schematic/ wiring diagram locate with inthe console itself usually taped to the back wall behind the timer
Posted on Apr 03, 2008
2 Suggested Answers
SOURCE: I NEED OWNERS MANUAL TO KENMORE DRYER
goto sears.com and under parts type the model# hit enter. Then type manual and it will cost you $2.30.
Posted on Oct 16, 2007
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
I need to know how to fix the dryer belt on model 110.97574100 (gas dryer).Also is there anyway you can email an owners manual for this. I bought it new but lost the manual
http://www.searspartsdirect.com
Kenmore Gas Dryer
Model #11097574100
Owners Manual does not have drum belt replacement instructions, but service manual does. -- SWT
Aug 05, 2010 | Kenmore Dryers
Hello,my kenmore dryer wont heat. i am not sure where the fuess are? thank you mike
There are no fuses internal to the dryer, except for a thermal fuse located with the strip heating element.
Let's start with the basics, does the motor turn the drum but the unit just does not heat?
Is this a gas or electric dryer?
Please provide Make and Model number of the dryer.
Dec 18, 2009 | Kenmore Washing Machines
Replaced the heating element what ever its called. and still not heating up' its politless
Disclaimer: I don't know this particular model, but in general, tumble dryers have 2 or 3 interlock switches that need to be checked:
1. Door interlock: this allows the drum motor and fan to energise and the heating element to be turned on: Does drum turn and fan come on? If so, it is not this.
2. Overheat switch: located in exhaust path of fan: usually re-settable - have you located this and reset it?
3. Humidity sensor (some models have this, some work on time only) - this can fail open circuit and the drum and fan won't come on. (Same check as number 1)
Jul 29, 2009 | Kenmore Dryers
Whirlpool gas dryer drum turns, heats for 10 minutes, then nothin
there is thermostat in the unite look at owner manual that what sounds like. basically it is sensor that tell the unite to turn off.
Jun 24, 2009 | Kenmore 63942 Dryer
My dryer is not heating, but all other things works find.
CHECK FIRST TO SEE IF YOU ARE GETTING 220 VOLTS TO DRYER ITSELF WILL RUN ON 110 BUT WILL NOT HEAT , CHECK FUSES IF ANY CIRCUIT , RESET BREAKER EVEN IF IT DOES NOT APPEAR TRIPPED CHECK FOR 220 VOLTS @ SOCKET THEN TALK TEAR DOWN
Nov 25, 2008 | Kenmore 659 Electric Dryer
Need manuals
What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
Apr 02, 2008 | Kenmore 63942 Dryer
Oct 16, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
579 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
