Question about Hotpoint RLA32
The compressor is running all the time and will not switch off even if the setting is reduced to its lowest. This only started recently and ice is forming at the top of the cabinet. The door appears to be sealing correctly and both interior and exterior appear undamaged. What else could I look at or check?
  • 269 Answers
It sounds as if the thermostat is faulty and will need replacing.
Posted on May 09, 2010
AC on 2003 Camry not cooling. What is solution?
The ac compressor has a switch under it most of the time people
replace compressor please be carful you have to discharge system before pulling swith off compressor even then that switch
let a pro take a stab at it danger I would take it to shop I work on car a lot replace compressor assemble better anyway last longer
to hot to break down do it right first time cheaper in the long runlong run
Mar 12, 2015 | 2003 Toyota Camry
Why on a 05 impala the ac clutch stays on
You are either low or out of Freon.
The cars sensors is telling the motor it's not cold enough so it's staying on which can burn out the bearings if not taken care of ASAP.
Aug 27, 2014 | 2005 Chevrolet Impala
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Unit was running and shut off. Now motor won't run. Seems to get initial click and then a hum.
Try trouble shooting it in this order
1. remove the v-belt connecting the motor and compressor
2. run the motor, if it runs well then check the compressor. try to turn the flywheel of the compressor by hand. if it turns alright then check the pressure switch.
3. check the setting of the pressure switch, it cuts off power to the motor when the preset pressure is reached, maybe it is set too low, adjust the pressure switch to a higher setting
Oct 18, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Kenmore 580.51650000 dehumidifier: compressor cycles on and off as it should based on humidity setting but the fan is always running, even with the compressor off. Checked humid sensor. Any other...
fan should turn off when compressor not running, the relay switch is stuck open for the fan, and probably needs replacing, but even if it always runs there is no harm and it only uses like 15 watts
Aug 21, 2009 | Dehumidifiers
05 Jeep liberty- A/C compressor runs in all phases
This is Common. The Compressor will run even on Heat settings. It is simply Priming for actions that the Owner could Initiate. Not a big Problem.
Jan 24, 2009 | 2005 Jeep Liberty
Whirlpool Side by Side Refrigerator is turning on and off not getting cold at all. Freezer section barely cool and the vents during the times its on barely puts out air
it sounds like a bad:
  • start switch (on the side of the compressor) or
compressor itself
  • the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 18, 2008 | Whirlpool Refrigerators
My philips fridge freezer (side by side) keeps clicking as if trying to do something. The issue only goes on for a short period of time and is not consistent in any way.
it sounds like it could be a bad (or possibly going bad):
  •  compressor itself
  • if the compressor is not even running then its probably not overheating.
  • so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Jul 01, 2008 | Refrigerators
Compressor runs even when turned off
You could have a relay stuck closed, so every time the power is on it feeds electricity to the compressor.
Mar 10, 2008 | Fedders AEY08F2FCOM Wall/Window Air...
Hotpoint RLA32 Logo
70 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
