Question about Kenmore Washing Machines
I have a top load kenmore washing machine and it is leaking at bottom front corner. what could be wrong
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on May 09, 2010
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Leaking from the bottom back
Hi, If not a hose leak, check for leakage around the water pump. On our top-load Kenmore, the leak showed up at the front right of the machine. Water was leaking where the pump slides onto the motor shaft. Replacement of pump consists of: (1) unplug power cord and then remove 2 screws at corners of the dial/control panel to tilt it back, (2) unplug wiring harness, (3) remove two spring clips holding white metal console to the frame then tilt console forward and remove, (4)pump was in front of machine with two black hoses attached via hose clamps - remove the spring clips at top & bottom of pump and remove the two hose clamps, (5) slide new pump onto shaft and reassemble in reverse order.
Take care
Jun 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore oasis He 27062 it is leaking out the back bottom rt corner. The hoses are connected what could be the cause
Hello,two Philips screws on the back or front corners
remove those and roll the control board up and over
you will see two clips on the each corner in back
pop those off,,,,, remember how they are positioned
once those are off you will see a two wire connector
unplug that, and the top part jump with a piece of wire
no you can roll the cabinet forward and off,
now roll the control back and turn the machine on.
Thanks
May 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
How do I remove the cabinet from mt Kenmore front load washer. It is leaking during the wash cycle.
Screws along the bottom of the front lower panel. This will get access to find the leak. If it is up high the top comes off with 3 screws at the back top edge and slide forward.
Eric
Jun 26, 2009 | Kenmore HE2 Plus Front Load Washer
Top load kenmore 110
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore Elite top load washer leaking
in the two front corners insert a putty knife and pry upward.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Removing the outside case on my kenmore washing machine
have you tried just leaning the washer back ?? if that is not a calypso the bottom is card board and just pulls down pump is on front end of motor 2 clips 2 hose clamps ..if calypso remove screws in bottom pump back right corner as far back as i can remember all full size top load kenmore washer pumps were accesible from bottom that's 35 yrs by the way
Jul 17, 2008 | Kenmore 24932 Top Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
