Question about Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw
The blade in my milwaukee sawzall broke off inside the blade insertion part. There is no-way to pull the broken piece out. Suggestions on removing broken off piece?
rowdy45176
  • 2176 Answers
SOURCE: Switch wireing for 6509-22 Milwaukee sawzall
go to Milwaukeetool.com and type in your model number in the block indicated and you will have a couple options i.e. a manual, breakdown and wiring schematic, all that you can download. Let me know if you need more help
Posted on Aug 10, 2009
  • 3 Answers
SOURCE: Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
Posted on Jan 21, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a Milwaukee sawzall 6509-22 with a quick
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Posted on Jul 29, 2009
  • 88 Answers
SOURCE: my milwaukee sawzall quik lok blade clamp will not
try pushing in collar or pulling out while truning
Posted on Aug 24, 2009
rowdy45176
  • 2176 Answers
SOURCE: milwaukee blade holder replacement
piece of cake. the number you need is 14-46-1011 and the cost is usually between 15 and 20 dollars. it comes with detailed instructions and a exploded parts list for this. About 10 minutes tops. If I have answered your request would you please rate this response accordingly. and if you provide me with city state and zip I will try and find one locally for you if in U.S.
Posted on Sep 14, 2009
Brand new saw. Vibration so heavy it's nearly impossible to use. Had two previous identical saws. Both ran smoothly with minimal vibration. Would still have those saws if not stolen. Used this saw twice....
immediately return it to place of purchase, it is defective and it is still under warranty! it is very rarely that there is something wrong with them, even broken blade is easy removed, but you described just something wrong from manufacturer side.
i have several milwaukee tools, including sawzall, love them, but they 28volt batteries sux...
Oct 03, 2013 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Milwaukee sawzall blade
Cut or snap the blade off at the end so you can get the holder apart. I have had to do this before. Usually you can just use a set of pliers and work the blade back and forth until it snaps off but I just use an air powered cut-off tool and cut them.
Aug 05, 2012 | Milwaukee tools Milwaukee 6509-22...
Cordless 18 volt lithium ion sawzall hums and clicks blade wont move
I don't know what model you have but Milwaukee sawzalls use a wobble shaft and wobble plate to turn the rotary motion of the armature into the reciprocating action of the blade. If you motor is working (hums?) but the blade won't move one or more of these parts are broken and hitting eacher (clicks?) inside the gear case. You or a repair center will have to take the gear case apart to find our what's broken and determine whether it's worth repairing.
Jan 27, 2012 | Milwaukee Tool Saws
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Milwaukee blade holder replacement
Sep 14, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Jan 21, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw Logo
1,533 people viewed this question
Top Milwaukee Saws Experts
Navin Sharma
Navin Sharma
john h
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
