2 cds are stock in my MD100. shredder will not work i cannot get the top off the shredder. can this top\ be remmoved at all to get these 2 cds out of the shredder. can you help?
    Guru:
  • 415 Answers
It may be possible to remove the collection bin and work from the underside of the shredder. Some of these shredders allow for disassembly with screws from the underside of the top. Some of the screws may be covered with a sticker. Manufacturers cover screws with stickers for warranty purposes.....it helps them identify whether or not unauthorized service took place.
These shredders also utilize plastic gears that will strip when something gets caught in the shredder portion. Once those gears are stripped, it is often best to purchase a new shredder.
Posted on May 09, 2010
Do primo 3900 shredder, shred CDs?
Capital Shredder offers a range of paper shredders in compliance with NSA/CSS Specification 02-01. This regulation became mandatory on 1 October 2003. It requires that all DOD Approved paper shredders meet exacting standards for maximum particle area and dimensions as well as tough new standards for durability. These paper shredders are engineered to meet the most stringent security demands of the Department of Defense, NATO, and other government, military, and commercial organizations worldwide. The crosscut action and small residue provides a reliable method of disposing of classified material including Top Secret, COMSEC, INFOSEC, CRYPTOLOGIC. All of these models meet the new DOD requirements and are available on GSA Schedule.
Nov 17, 2016 | Office Equipment & Supplies
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
I just bought the Omnitech 10 Sheet Cross Cut Shredder. Is it safe to shred papers with staples in them?
I don't have that model but have an 8 page cheapo shredder. It takes CDs, credit cards and staples with no whining.
Oct 23, 2013 | Omnitech 12 Sheet Cross Cut Shredder
Ativa shredder manual
Are the shredder blades going around? most shredders have guides that guide the paper between to shredder gears or teeth. these guides are usually made of plastic and breake. First step is to see if the shredder gears or teeth ar going around.....
Sep 23, 2013 | Office Equipment & Supplies
Red light and green light on but motor will not come on
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 13, 2013 | Fellowes PS60-2 Shredder
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
My Fellowes p600c-2 shredder will only run in reverse. I've blown compressed air on the switch and pushed on it with a toothpick but neither method worked. I removed 6 screws and the cover of the on/off...
Never mind providing help, I fixed it myself. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Jan 17, 2010 | Fellowes P600C-2 Shredder
Stock 1997 Ford Explorer 6 CD changer stopped playing CDs
We finally realized that all of the "advisers" on the internet want to charge for their advice, and their advice in this case is univerally that the unit should just be replaced. Ya think?! Could of figured that one out on our own.....what a joke...
Mar 31, 2009 | Car Audio & Video
Shredder won't shred - all paper is cleared - works intermitantly
Run the shredder in "Reverse" mode for 15 seconds.
Oil the cutting head thoroughly as this is a High Security shredder.
Test it at 4-5 sheets.
They always overrate the capacity but if you want to keep it operating, shred 3-5 sheets max.
Running for serveral minutes could be due to dirty optic sensors. Unplug the shredder, remove the top (2 screw underneath front and 2 in back). Remove the sensors (they have a little pushbutton tab) and clean thoroughly with a soft cloth. Re-insert the sensors ensuring they lock in place, reset the top cover and test.
Jun 05, 2008 | Geha Primo 3900 HS Shredder
Where I can get spares?
Try there: http://www.espares.co.uk/partnotlisted.aspx?k=XR-MD100
Dec 21, 2005 | Aiwa XR-MD100 Shelf System
32 people viewed this question
jasbo
jasbo
