Question about GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
GE Adora ice & water dispenser inop and display flashing zeros
My problem is with a GE Adora refrigerator purchased in 2006.
The model number is DSS25KSTA SS.
This model has a display and controls on the freezer door above a dispenser for water, crushed ice, and ice cubes.
A few days ago, the dispenser stopped dispensing ice - no crushed or blocks. I also could not hear the familiar motor/auger noise. I checked the tray and there was plenty of ice. The ice was loose enough in the tray that it should not have prevented the auger from turning.
Today the water stopped dispensing as well.
I checked some troubleshooting tips on GE's website, and decided to try unplugging the refrigerator for at least 30 seconds to reset the dispenser board. After plugging the refrigerator back in, the display started flashing zeros. It alternates between flashing four zeros and flashing one zero at a time. I could not find this symptom on the GE site.
I would appreciate some advice as to the next step.
  • aircav11 May 09, 2010
    This problem is fixed. I removed the grill at the bottom of the refrigerator, revealing the connectors/tube shown in the photo. As soon as I moved the tube, the ice maker made some noise. I looked up at the display, and it was no longer flashing zero's. I tested the dispenser, and now everything works. Not sure why moving the tube around fixed the problem, but I'm glad it's fixed.
    Also, note that one of the electrical connectors is not connected to anything. I don't know if that's normal, but I couldn't find any other connector that it could have been disconnected from underneath the refrigerator. I'd still like to know if this is normal.
fridgetech
  • 473 Answers
SOURCE: crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid.  The solenoid is bad.  When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out.  First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down.  You can take out the ice bucket and press for cubed ice.  You should hear a loud clunk noise.  If not then you know the solenoid is not working.
Posted on Oct 11, 2007
SOURCE: Icemaker problem crushed only not cubes
I looked at the plastic piece the solenoid was moving (from Guest's comment 03/07/08). Pushed the plastic piece up (had to push pretty hard) and it reset the solenoid to its' start/beginning position(-?) Plastic piece came back to lower position - was free to move up and down. The solenoid is working now (hear the loud clicking and see it pulling the plastic piece up) to get cubed ice, instead of putting it thru the crusher.
Posted on Mar 15, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
MNTECH
  • 1543 Answers
SOURCE: PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Posted on Nov 20, 2008
peyton32034
  • 410 Answers
SOURCE: icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Posted on Jan 22, 2009
I have a GE Adora, side by side, the ice gets clogged in the blades of the crusher and prevents ice from dispensing.
It does sound as your water valve letting water to drip and it will fill and freeze. To check watch the ice cubes. Are they as cubes or all in one .
May 29, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
Need to replace Ice & Water Dispenser for msd2354 side by side refriderator, how to get the unit?
use your model number to order it from marcone.com, they will give you a parts breakdown and you can get any part you want
Oct 12, 2012 | GE GSS22JF Side by Side Refrigerator
My GE Adora Refrigerator is making ice but not dispensing it. What could be the problem?
The switch for the screwfeeder is probably not any good. With ice or not, the screwfeeder should turn when you push the handle in to dispense ice. If there is any ice in the hopper, it will get drawn in by the screwfeeder and sent out the dispenser door in to your waiting container.
Oct 08, 2010 | GE Adora (DSF25KGTBG) Side by Side...
I'm having problems with my Adora fridge. First, the contents in the crispers started freezing. The storage tank behind the drawers seems to be frozen. Now the water won't dispense. Ice is being made...
Your model has a WR60X10132 or 10055112 Damper and Fan that regulates temperatures between the freezer and fresh food compartment. The part has been recently updated. Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator.
(The manufacturer has replaced part number wr60x10132 with this item, part number WR49X10091.) (Manufacturer part number WR49X10091 is RepairClinic item number 1055112.)
BRB with photos and locations. Sea Breeeze
Jan 23, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
The water dispenser on our GE Adora refridgerator (DSS25KGRA) stopped dispensing water. The internal icemaker still makes ice and the door unit dispenses ice both cubed and crushed. Could the water line be...
Most of the time it is the half of the dual water control valve on rear of refrigerator. The part number Click Here=> WR57X10032 Usually the coil on that side will go bad before buttons or controls. You can test that side by setting a test meter on AC voltage and you should read 120 volts while someone presses dispense water on front. There are two sides one plugs into icemaker side and other water dispenser. When replaced they both come as a kit. If you would like you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Ice dispenser/Water dispenser not working
I will need to get your model number to help you better. Thanks Sea Breeze
Jul 26, 2009 | GE Refrigerators
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
The water and ice dispenser is not working, the light goes on and off to normal and dim. There is a low tone bonging sound. Fridge and freezer work, but lights and ice and water dispenser don't. the...
if your refrigerator is only a year old. it should still be covered by your warranty, if any one works on the refrigerator while still under warranty, your warranty is expired. So check before you put your hands on it. sounds like a power problem, maybe an open fuse etc....
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator Logo
195 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
