Question about Kenmore 15218 Mechanical Sewing Machine
What size bobbin does the machine use? - Kenmore 15218 Mechanical Sewing Machine
    Genius:
  • 1,116 Answers
The standard size is Class A or 15.
Posted on May 09, 2010
Can I only use the small bobbins supplied and if so where can I get further supplies
The bobbins depend on your machine make & model. Use the bobbins that came with your machine. Not sure what you mean by "small" bobbins. There are quite a few bobbin sizes but bobbins are usually specific to your machine. Singer #15 bobbins are common and readily available at most sewing shops but definitely will not work on all machines. Some bobbins are only a millimeter difference in size but will most likely cause problems with your machine. Just because they may fit in your machine, doesn't mean you will get the best result, if not broken, tangled thread, etc. Sometimes, those bobbins will get stuck in the bobbin case making it difficult to remove. If you want to order more accessories, search for:
Make Model accessories
Mar 12, 2018 | Sewing Machines
"bobbin size
Consult your owner's manual to find out what bobbin to use in your machine. There are many bobbins available, some will actually fit in your machine, but they may be a slight bit different size that will negatively affect your machine's operation. If you don't know which bobbin to buy, take the machine's manufacturer name and model to a sewing shop and ask if they can sell you the bobbin for your machine. Better yet, find a local dealer who supports your particular machine's manufacturer. You may even find the appropriate bobbin online by searching:
Manufacturer + Model + the word "bobbin"
Dec 30, 2015 | Sewing Machines
What size bobbin for White 915?
On sewing machines with the removable metal bobbin case the bobbin size will be a class 15, very common and inexpensive.
Dec 10, 2015 | White Sewing 915
Need Bobbin size for Janome Jemsilver model 662
There are three sizes (classes) of bobbin that most machines use. If you have the old bobbin and can measure it this link will help you determine which class you need.
What Size Bobbin
Jul 19, 2014 | Janome Sewing Machines
Bobbin tension to loose and flips
Hai, I think you put the big size bobbin. So only jumping the bobbin. Please try to put the correct size bobbin.
Apr 03, 2014 | Brother PE770 Computerized Sewing Machine
I can only get non elna bobbins. what size should I look for
Do you have an elna 7200? If so it uses class 15 bobbins part # 2518P. These are the most common bobbins in the household sewing machine market.
Jan 15, 2014 | Elna 7200 Pro Computerized Sewing Machine
What type of bobbin should I use in my Memorycraft 4000.. Plastic or metal..I have been using metal, is this ok?
You should be using plastic bobbins for the MC4000, see: http://content.janome.com/index.cfm/Machines/Accessories/All/Bobbin_-_Plastic . Usually the machine comes with a handful of the correct size and type bobbins. Using the wrong bobbin could result in the needle hitting the bobbin and damage may occur. (Broken needles are the most likely possibility; damage to the bobbin case or timing could occur and would require the machine be serviced.)
When you buy more bobbins, make sure that they are labeled for Janome or a machine that takes the same size bobbin. See this site for a list of machines that also take this size bobbin: http://www.sewingmachinesplus.com/102261103%20-20pk.php
I hope this helps.
Mar 01, 2011 | Janome Memory Craft 4000 Sewing Machine
Bobbin size
This machine uses a class 15 bobbin.
Nov 01, 2008 | Simplicity Fashion Pro SW2145 Mechanical...
Bobbins for viking emerald 118
The Emerald 118 takes a bobbin that is very close in size to a Singer Class 15 bobbin, but it is slightly different.
Don't buy green bobbins for a standard Husqvarna machine. They will not work.
Any Husqvarna dealer can get the Emerald bobbins for you.
Oct 03, 2008 | Husqvarna Viking 1
Kenmore 15218 Mechanical Sewing Machine Logo
170 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
