Question about GE Monogram ZEU30RSFSS Stainless Steel Electric Cooktop
F-113 code The hot surface indicator light for the large front left burner remains on. I have powered off the unit and it still comes back. Any ideas? Expensive repair? Burner works fine.
  • Tonythetiger Mar 29, 2008
    More information from Tonythetiger:
    GE Monogram ZEU30R (Stainless Steel)
    The burner does NOT go on. The code F 113 comes up when trying to turn on the burner. What does the F 113 code mean? The hot surface indicator light remains on all the time. If repairable, what is the part number? I would like to repair it myself.
    The affected burner is the front left.
    Thank you.
  • Tonythetiger Apr 26, 2008
    I have the manual and I haved already attempted what the manual suggested without success. I imagine that Code F113 is a diagnosis code and I am looking for the diagnosis without having to call a serviceman. When your automobile service engine light goes out you can have someone at Autozone get the diagnosis code and tell you what it means. What does F113 mean? I had anticipated by paying for this service that it would provide more information than what is already in the manual and that someone out there has seen this code F113 before and knows what it means. What part is broken when you have a code F113? What is the part number? Any further help is appreciated. Thank you.
    President:
  • 2,712 Answers
Hello tonythetiger,
Well, according to the information I was able to glean from the instruction manual, you have to touch the 'control lock' pad, disconnect the power to cooktop, and reconnect. If the F code appears again, you will need to call for service.
According to their website, there are two ways to schedule service:
  • Schedule Monogram Service Online
  • Call 800-444-1845, where our Monogram Preferred Service Specialists are available 7 a.m. – 10 p.m. ET Monday through Friday and also 8 a.m. – 6 p.m. ET on both Saturday and Sunday to coordinate your service appointment.
You may also write to:
  • USA:
    Manager, Consumer Relations
    GE Monogram Appliances
    Appliance Park
    Louisville, KY 40225
  • Canada:
    Mabe Canada Inc.
    1 Factory Lane, Suite 310
    Moncton, N.B. E1C 9M3
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 26, 2008
  • 3 more comments
  • Swilin Sampson
    Swilin Sampson Apr 26, 2008
    Just checking to see if your issue has been resolved…If it has,
    please take a moment to close this problem ticket with a FixYa! rating. I would
    be very grateful for your gesture of appreciation.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    I am afraid I am not able to find out what the error code f113 means. I scoured every available resource, and GE are not very forthcoming either, as I am not a customer.
    It could be something as simple as replacing a capacitor or sensor, but unless you know exactly where to look and what the code actually means, it's like looking for a needle in a haystack.
    If you want to know what the error codes stand for, your best bet would
    be to visit a local GE authorised dealer or write to the address I
    provided above.
    Hope that helps, and good luck.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 27, 2008
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Apr 29, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything else
    I can assist you with...
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 04, 2008
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    appreciation.
    post them here.
    Cheers!
    IrishDruid
    Genius:
  • 1,447 Answers
Here is what the error code means
SOURCE:
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
Sep 06, 2008 | KitchenAid 30 in. KECC506R Electric...
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
GE Monogram ZEU30RSFSS Stainless Steel Electric Cooktop Logo
395 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Steve Allison
Steve Allison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
