Question about Dryers
DRYER DRUM WILL NOT MOVE - Dryers
  • 10,319 Answers
Check out my dryer tips if you wish
The belt and tensioner may need to be replaced
Posted on May 09, 2010
I have got whirlpool condenser dryer model AWZ541/3 but the drum does not seem to move does the drum spose to move or not
yes the drum should move sounds like the belt has snapped or the start capacitor for the motor is faulty
Regards
Ian
Apr 17, 2011 | Dryers
When dryer starts the drum wont move..it is a Roper large capacity electric dryer non stackable
If the drum won't move but you can hear a motor running, the drive belt has probably slipped off of the drum or motor pulley or has broken. Try turning it by hand with the motor off and then turning the dryer on again.
Oct 24, 2010 | Whirlpool Dryers
The dryer drum will not spin. We can move it
the belt and or tensioner is at fault. both should be replace at the same time if one is out
Feb 24, 2010 | Dryers
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
Dryer won't start spining the drum
The belt is the likely culprit, you have to look inside to see if it is the belt
May 03, 2009 | GE DWSR405EBWW Electric Dryer
Drum wont move
you should take off the bottom panel on the front of the dryer. there is usually 2 screws on the bottom. from there, you will be able to see if the belt is on and if you move the drum with your hand as you look inside, you will see if the belt is moving like it should
Oct 27, 2008 | Hotpoint Dryers
GE #DVL226EB6WW
Here is a link to parts and drawing for your dryer: http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
If the drum won't move, likely culprit is the belt
Jun 08, 2008 | GE DVL223EBWW Electric Dryer
Drum does not move
dryer...there is no way to lubricate anything...all bearings are sealed. Get in there and look around. Turn off the gas and remove the line of you can't get access... and disconnect the power. Remove the back. Chances are you'll find that the motor, drum or belt is somehow jammed. Make sure any fan is turning freely with the belt off. It is possible that the timer is bad. This would keep the motor from receiving power. To test...remove the motor belt and turn the unit on.
Dec 16, 2007 | Estate TGDS740JQ Gas Dryer
Dryers Logo
Top Dryers Experts
