Question about Singer Featherweight II 117
Lost instructions for threading lower bobbin how
Lost instructions for threading lower bobbin how is it done
    Genius:
  • 1,116 Answers
You can find the instructions at the Singer Company web site - http://www.singerco.com/resources/bobbin_wind.html
Posted on May 09, 2010
What to do to fix the bobbin thread from jamming up everytime
There are a couple of reasons that can cause this.
a. Raise the pressure foot. As you load the top thread give small tugs to check for snags. They must be stopped.
b. Once the top threading is done on top lower the pressure foot. Now, give a tug on the thread. Is the tension really hard or just average? You may need to lower the tension to stop the jamming of the bobbin thread.
c. Clean the bobbin area. Check the bobbin tension and adjust as you need to.
d. Put a drop of oil on the race. (Thing the bobbin case sits on)
e. As the bobbin hook (sharp thing) is rotating does the bobbin case move back and forth a lot. You may need to adjust the bar that is next to the bobbin case so it can't rotate. Usually you will need to move it forward.
SEE INSTRUCTIONS HOW TO ADJUST THE BOBBIN. TENSION OF UPPER AND LOWER THREAD MUST BE RIGHT.
Nov 28, 2015 | Sewing Machines
Bottom thread will not be pickup
There is loose thread hanging from the lower bobbin, isn't there?
Dec 12, 2013 | Necchi 4595 Mechanical Sewing Machine
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
Threading a bobbin on the new home 2014le
place spool of thread in , route it towards your bobbin holder, take thread and put through one hole about 4 inches hanging ontop. press it in and slide it to the right where you hear a click, hit the peddle, should be winding, it will automatically stop on its own when full. click it to the left when done, snip it and then drop that into your bobbin holder , cover your plate, thread your upper thread and presto you are now sewing with your threaded bobbin, always remember these steps. #1 material choice #2 thread weight #3 needle size. you got to match those 3 for beautiful perfect stitches.
Dec 16, 2009 | New Home 2014LE Mechanical Sewing Machine
Thread is stuck in bobbin
THREAD STUCK IN LOWER BOBBIN IS COMMON BUT GETTING THE LOWER BOBBIN OUT IS THE HARD PARTYOU WILL HAVE TO FIND OUT HOW MUCH THREAD IS RAPPED AROUND THE OTHER ITEMS IN THE MACHINE AND START SNIPPING THESE TO REMOVE THE BOBBIN CAN BE DONE BUT CAN BE VERY TIME CONSUMING AND TEDIOUS
Aug 10, 2009 | Kenmore Sewing Machines
Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Jul 29, 2009 | Sewing Machines
Can not get bobbin to thread
Ok, while I can't find your exact model, I found the closest number for threading/bobbin instructions:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Necchi_Sewing_Machine_Threading/Necchi_4795_threading_Diagram.htm
And this site has instructions for many more Necchi machines:
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Mar 22, 2009 | Necchi Sewing Machines
Brother sewing machine ls2125
Don't go directly from the thread spool to the bobbin.
You have to go via the thread quide, (near the end of the head at left side) and under the small roller.
Pass your thread to the bobbin turn your thread 3 turns to the right, clockwise,
then pass the end of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Push the thread winder lever to lock the bobbin.
Start winding slowly. If the thread is loading in the down position,
put your finger under the thread between the bobbin and the the thread quide, untill you see that the thread is feeding evenly.
Jun 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother PE 400 D threading bobbin problems
im going to help you as much as i can,,,,try using a bobbin that is already threaded and make sure bobbin is in bobbin case correctly, make sure machine is threaded to instructions in book,,,if this is all done exactly u should not have a problem unless something is jammed
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Singer Featherweight II 117 Logo
584 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
