Question about Curtis CM27002S 27" TV
How to hook up to computer
I have a vga to component cable and I was told by useing this I could make my tv my computer monitor. The cable comes with a vga plug on one end and rca male plugs on the other, the rca plugs are colured red greenand blue . How do I connect this , and what do I have to set the tv to so the signal comes through ?
2 Suggested Answers
SOURCE: Curtis 5.1 Home Theater System
can it hook up to the cable and have the sound can out the speaker when wacth tv . so one can here it with not be so loud for the for any oneself,in the roon with then .
Posted on Jan 14, 2007
Tip
How To Connect Flat Panel TV to Computer
Hello <br /> First identify your TV's input connections. Most TVs these days have three basic types of inputs. You have your coaxial cable input, the same as your cable box or satellite, an RCA composite input (the yellow, red and white inputs) and an S-video connector. Newer televisions might have Component Video, DVI, VGA or HDMI inputs but the ones listed above are more common. <br /> Identify your computer's outputs. These days computer manufacturers are adding TV compatible outputs on their products so it's easy to have a pc to tv connection when you hook it up. The S-video in particular seems to be popping up on more and more computers, so a PC to TV S video connector might be what you need. You can shop for S-video cables all over the place online. Mostly you will find the usual VGA output that the regular monitor hooks up to (see more later on VGA cables). The newer multimedia computers will probably have all high definition outputs that connect directly to your HDTV, but for now we will deal with what most people have for both computers and televisions. <br /> Find the appropriate adapter for your connections. You may need to get a computer to TV cable so you can hook up your computer to the TV. If you have an HDTV, you may need a VGA to component cable. This VGA to component cable connects your computer to a HDTV and acts as a converter. (And that computer could be either a Mac or a PC.) <br /> A PC to tv connector has a VGA adapter on one end and (usually) a selection of connectors on the other (S-video, RCA composite and Component). The good thing about these is that you can take it from TV to TV and you'll be able to hook up computer to TV for all of them. I highly recommend a wireless adapter. It costs a bit more but wireless is worth not having a big cable mess and not keeping your computer near your TV. <br /> or you can get help from this video <br /><br /><img src="utube.png" /><b><i> You-Tube video "ZCN-nN1orYE" placeholder (do not delete) </i></b><img src="utube.png" /><br /><br />Hope this helps, if so do rate the Tip.<br />
on Jan 25, 2011 | Televison & Video
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Can I connect the LC19DV22U to my computer to use only as a monitor? And if so, how. I have misplaced the manual.
where did you hooked up the cable at the tv, what component input did you use like HDMI or VGA port? if your pc has the vga output you will use the vga port input of your tv then select in the source PC to get the signal from pc.
Oct 16, 2012 | Sharp LC19DV22U 19 in. LCD Television
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
How do I hook up my hp computer to my lg flat screen tv
You can use the TV's VGA port which needs a VGA cable which you can get from a computer hardware store. It's called RGB in on your TV. This is also called PC input.The max resolution you will get is 1,366x768 off your PC.
Jan 25, 2011 | LG 32LG30 32 in. LCD HDTV
HP Laptop to TV
You cannot connect VGA OUT to component IN on your TV without using a converter. However, You can connect VGA OUT from your laptop to VGA in on your TV using a VGA cable just as long as your TV has VGA in. You will need to hold the FUNCTION or FN key on your laptop while press the F4 or F10, whichever F key has the picture of the monitor on it. This will switch your laptop from LCD to external display or both.
May 02, 2009 | HP Televison & Video
Curtis CM27002S 27" TV Logo
62 people viewed this question
Top Curtis Televison & Video Experts
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
