Question about Microsoft Xbox 360 Console
2 red ring of death
How can i clean the inside of the 360. and how to make it overheat less. How can i stop the overheating??
  • 46 Answers
Use a very small screw driver to pop the clips on the cover, be patient its a ball ache job! then try using a can of compressed air to blow dust and stuff away.
make sure its in a well ventilated area.
Posted on Mar 27, 2008
Air compressor starts and then shuts off
Do you mean it runs for 1 or 2 seconds and stops or it runs for minutes and stops? If it never really starts (runs for a second or less) then it is probably a capacitor start motor and the capacity has gone bad.
If it runs for minutes or more and then stops and subsequently restarts when it has cooled then the thermal overload switch is turning it off when the motor overheats. If the unit is not all that old, hasn't been run particularly hard and you have this problem every time you turn it on when it is just pumping up, (which is to say, there is no good reason for the motor to be overheated) then the thermal overheat switch is probably defective.
If the compressor is being run hard when this happens, then the unit is being overheated from heavier use than for which it was designed. If the interior of the compressor motor has a coating of saw dust or dust, it acts like an insulator and results in the motor heating more quickly than it should under normal circumstances. Also, if it is being used in a hot environment it will likewise have trouble cooling.
So, if it really doesn't run at all, it is probably the motor starting capacitor. If it happens when the compressor isn't really hot, then the thermal over-temperature switch is probably defective. If it gets genuinely hot, but without being run hard, then the motor might need to be cleaned because it is not cooling properly. If it happens when it is hot and it is hot because it has been run hard, then either don't run it as hard, cool it better or get a bigger compressor. If it is clean inside, not being run hard but still overheats, then I would look at a malfunction in the compressor portion of the unit having more friction than it should (bearings lubricated?) thus requiring more horsepower to run the compressor than the motor is designed to generate and results in overheating. Low voltage can also do the same.
Aug 03, 2012 | Coleman Air Tools & Compressors
Xbox 360 will appear with three even after i cleaned the thermal grease and did the penny trick any other solutions?
Cleaning the thermal grease and doing a trick with few pennies doesn't solve anything, the problem is that the soder between the Cpu / gpu and the mainboard melted during overheating and is not making the proper contacts the only way for you to fix it at home is to overheat the console again with the heatsinks loosened a bit so the components have room to move a millimeter or less to the right position and the console will work again. If not, read the secondary error code by pressing the controller reconnect button down together with the eject disc button, the flashing code will change, write down how many leds are flashing, then press the buttons again, and write down how many are flashing, repeat 3-4 times until your back into the "Red right of death". Tell me code you got, for example 4422 (4 digits)
Jul 13, 2011 | Microsoft Xbox 360 Console
I get 3 redlights on 360 system but via component and tv get no signal
lawls it juust over heating Just let your system cool down :)
May 26, 2010 | Microsoft Xbox 360 Console
My xbox freezes and flashes red
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
Stop the heat and you will be fine.
Feb 27, 2010 | Microsoft Xbox 360 Console
How do i clean xbox 360 len?, xbox keeps saying my disk needs cleaning, the disk is spot-less, after 3/4 of an hour (appox), it loads the game. Thanks.
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
Feb 24, 2010 | Microsoft Xbox 360 Console
What would cause a 2 ring malfunction?
2 red lights is purely overheating.
Feb 22, 2010 | Microsoft Xbox 360 Console
After playing a game for 5 min. or less playing on an xbox 360, the screen turns off and the xbox has 2 red lights on the ring of light the console is still on and the controller is still doing what it was...
Jan 20, 2010 | Microsoft Xbox 360 Console
I av an xbox 360 and it will play for 2 to 3 hrs then 2 red lights come on then it shuts down bought extra fans still it overheats any idea
COMPLETELY OPEN YOUR XBOX it may be ugly but it worked for me well your at it clean the thing after a while put it back together it should work fine
Oct 29, 2009 | Microsoft Xbox 360 Console
Xbox overheating
the ps3 does overheat and it gets the orange light of death when it does
Apr 24, 2009 | Microsoft Xbox 360 Console
X box 360
I hope you have warranty. your xbox is overheating and well, that is that. if you have a warranty then you can send it in and get a new one. If you don't I believe it is about $150 or a bit less and you can send it in a get a new one. One odd trick that I have learned about is wrapping the unit in a towel and allowing it to overheat. This will eventually will put out the overheating and it will work just as new. just remember when not in use, take out the plug. connie
Jun 21, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
