Question about Kenmore 5 cu. ft. / 142 liter Chest Freezer 11511
Used Kenmore freezer won't get cold enough
I bought a used Kenmore chest freezer. It is only about 5 years old and appeared to be in nice condition. Got it home and plugged it in and it has power. I left it plugged in overnight and it has not gotten cold enough to freeze an ice cube. It is cool, but barely. I have put it on the coldest setting. What could be wrong?
    President:
  • 949 Answers
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
Posted on May 10, 2010
I unplugged my chest freezer to clean it out, when I plugged it back in it won't get cold. It's in excellent condition. Never has it gave me a problem. It's approx. 5 years old. Ed V
Try turning the thermostat down to O and then back to max a few times this may free a stuck bimetallic strip. If this doesn't work and assuming you haven't damaged any components in some way then all that may be required is a new thermostat.
Nov 28, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
I have just bought an old kenmore freezer
could be freon to plugged freon lines probably not worth the cost of a service call and if it's that old it uses r-12 freon very expensive .Tom
Jun 15, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Used chest freezer not cooling
chest freezer operation is among the simplest available. if the compressor is running and its not cooling there are only 2 possibilities. low or no refrigerant and or a bad compressor. so if you have the ability to return the unit I would. could luck peyton
Feb 01, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Kenmore 5 cu. ft. / 142 liter Chest Freezer 11511 Logo
342 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
