Question about Hotpoint Aquarius WMA42 Front Load Washer
After washing whites clothes covered with black bits
After washing whites clothes covered with black flakes.looks like greece
    President:
  • 2,468 Answers
Your lip seal is leaking and the bearings are getting water in them,you need to get this fixed soon,because they can lock up if left too long like this and it will only get noisier and not better with time
Posted on May 09, 2010
Testimonial: "thanks very much.put me on the right path."
Waht causes black flakes on clothes when washing?
Hi, it sounds like you have to buy one of the inside washing machine cleaners its a liquid that you put in the washer and let it run its cycle to flush clean the interior of the unit.
Jan 23, 2016 | Samsung 4.8 Cu. Ft. 13-cycle...
What kind of cleaner should I use for my clothes washer ?
We had black flakes getting into the wash drum thru the drum holes. We ran one gallon of white vinegar through a regular cycle with great success.
Oct 04, 2014 | Bosch Vision 500 Series Front-Load Washing...
Is there a filter in the machine that \i should be cleaning as i keep getting black bits on the clothes?
The black bits are scum flaking off from between the inner & outer bowls, usually more common with cold water wash. Place old towel in washer, fill washer to high level with hot water, add washing soda & or vinegar, let washer run to end of wash cycle, turn off & let it soak for around an hour, turn back on & let it go through cycle. Commercial washing machine cleaning products should also be availably in your supermarket / hardware stores. You may need to repeat process until no more gunk comes out.
Dec 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
When doing black clothing they come out with white stains all the time. I am not using fabric softener, also using liquid detergent. help
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
Mar 27, 2011 | Maytag LSE7806A Top Load Stacked...
I have an updraft evaporative cooler. I get a lot of white flakes coming through my vents. Looks like hard water calcium flakes. How do I resolve this issue?
clean and service the cooler. remove the filters and gently wash them with a garden hose. isolate the power to the unit and wipe components with a damp cloth
Oct 12, 2010 | Mastercool 67680 Evaporative Cooler Air...
Hi. I have a Kenmore Elite top-loading washer and in every wash load there are flakes of brown stuff, not rust but more like leaves. There does not seem to be anything wrong with the outflow. Thanks!
Run a few washes of rags or towels with plenty of BLEACH & VINEGAR (two quarts of white) a couple of times to remove most bacterial debris from your machine. There is no part of the machine that "creates" brown flakes, so it is either in the water inflow (check the water) and the way to see what is coming into the machine is to do a "load" without any clothes! Just have the tub fill and look at what fills.....Sounds like something under the tubs upper lip that's coming-off and into your tub during the wash and agitation cycles.
Oct 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My lg Washing Machine WF-T853A is putting black rubbery chunks and flakes through every wash.. This has been happening for about 12 mths and is getting worse to the point where half the lint bags are full...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
May 12, 2010 | Washing Machines
Flakes of dirt on washing
Is this perhaps a second hand machine or it has possibily been stored away for some time? When a washer dries out inside ( behind the washer bowl ) and is then put back in service, dirt from years of use caked on insides flakes away ( like a dry leaf crumbles) and re-enters the wash and can end up on washed clothing. The only way to stop this is complete removal of washer bowl , scrub and clean insides to remove caked on dirt - reassembly. problem fixed !
Jul 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
558 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
