Question about Refrigerators
Neither fridge nor freezer working .fan at back on bottom runs for about two seconds then clicks offwhen iunplug and plug it back in
    President:
  • 2,468 Answers
Your ptc overload relay on the compressor body needs to be replaced and hope this takes care of it and the compressor isn't locked up
Posted on May 09, 2010
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
Hi i have a wirlpool fridge the freezer and fridge works fine but it seems the motor keep on running and dont switch off or is it the fan that is running please help
Hello Sandra;
My name is Peter. I am a retired field service refrigeration technician.
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
Dec 21, 2014 | Whirlpool Replacement Refrigerator...
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
My hoover hfa29k fridge freezer originally started to freeze the contents of the fridge and appeared to be running continuously.I unplugged it and left it for about an hour and then switched it back on...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Try this and let me know.
Feb 22, 2011 | Hoover HFA290K Bottom Freezer Refrigerator
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
4. Wait one hour.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
The freezer is working yet the fridge is not I
pull the frig out from against the wall and unplug then remove the cardboard backing be carful your going to put it back on and see what got lodged into the fan blade that cause it to stop when you cleaned the coils remove the object and plug back in ensure the fan start up put backing on push back
Aug 20, 2009 | Refrigerators
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
