Question about Whirlpool LER5634L Electric Dryer
No hot air
The dryer spins but the clothes don't dry. There doesn't seem to be any hot air going into the dryer.
  • 10,319 Answers
Clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
Posted on May 09, 2010
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Whirlpool gas dryer (LGR8648PW1) doesn't stop spinning in automatic mode.
More than likely a bad timer assembly. They are usually easy enough to replace if you have basic mechanical skills. The part can be ordered from repairclinic.com.
Jun 26, 2012 | Whirlpool Dryers
My dryer runs and heats up but doesn't dry the clothes. i noticed some dampness on dryer door when i open it. the clothes circulate but don't fully dry. i noticed the dryer is heated and light is...
Hi mandolins23...
Sounds like your venting system is plugging up, try these suggestions below...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Aug 30, 2011 | Kenmore 600 7962 Dryer
Dryer spins but doesn't blow hot air to dry clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-=
Aug 27, 2011 | Dryers
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Whirlpool LER5634L Electric Dryer Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
