Question about Maytag Neptune MDE5500AY Electric Dryer
Loss of power to the display
I opened the dryer then shut it and it wont come back on i unplugged it pluged it back in and nothing it is getting power the inside light still works.
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerloss of power to the display - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryeloss of power to the display - 2_bing.gif"http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 12, 2010
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
JUST MOVED TO A NEW LOCATION AND THE BRAVOS DRYER WONT WORK.POWER BUTTON WILL NOT POWER DOWN AND PAUSE START BUTTON WILL DO NOTHING.
Double check the power source, you may need to reset the breaker. It would be rare that the dryer would fault internally during transit because a gas ignitor you be the loss and you do not have one. Check the power supply and confirm you have at least 220 volt to wall and dryer. Get back to me if you need more help.
Thanks
Nov 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I opened my fridge to get something out, shut the door and EVERYTHING WENT OUT??? No lights, no nothing??? I tripped the breaker and checked the cord etc... Nothing????
Make sure your getting power at the outlet by pluging in somthing like a hair dryer. If your getting power at your outlet then you probably have a controlboard problem.
If you don't have power then first look for GFI RESET in the kitchen. or fuse box.
Aug 11, 2010 | LG LFC21760 Bottom Freezer French Door...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Oven wont work
ok an oven won't work withought the time set i am not sure which one you have but usually if you press all the buttons together the oven will then work
Apr 03, 2009 | Kenmore Ovens
PF ON DISPLAY FOR A COUPLE OF SECONDS
PF is a power failure. The unit is detecting a loss in power, but it should operate fine after the code is cleared (unplugging and plugging back in).
If the problem persists, then either you have an issue with the AC power coming from the wall outlet or the main board is faulty. Also make sure to check all the connections on the terminal block (where the AC cord attaches to the dryer) to make sure there are no loose wires or screw terminals.
Jan 18, 2009 | Kenmore 63942 Dryer
GE. Microweave Oven, Model JVM 1090
If your microwave won't start and the display is blank and unresponsive, the issue may be with the ceramic fuse. This part protects other microwave components from power fluctuations, and causes a complete loss of power when it fails, meaning your microwave won't work. To access the ceramic fuse, located inside the cabinet near the power cord, first unplug your microwave. Use a multi-meter to test the continuity of the fuse. They look like this:
If the oven will not power up, but you are getting some display lights ... then it could be a thermal fuse in the back or a faulty door switch.
Helpful?
Good luck on your troubleshooting!
Mar 04, 2018 | Ovens
Cyberhome DVR 1200 broken!!!
sounds like the power supply---open and check the power supply for bulged caps--replace those
Jun 18, 2008 | Cyberhome DVR 1600 DVD Recorder
Maytag Neptune MDE5500AY Electric Dryer Logo
53 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
