Question about HP LaserJet 4650n Printer
Unable to read cartridge data. for an HP laserjet 4650n printer. I says it cannot read the cartridge, and to try removing and reinstalling that peice of hardware. where on the printer is it located?
SOURCE: Printer telling me to remove and check right bay ink cartridge on hp 2410
Just some ideas you probably already tried: 1. make sure you took off the bit of paper / tape covering the vulnerable bits. 2. try another cartridge and/or a friend with similar machine & cartridge 3. make sure you load it correctly: only when machine is turned on, the slight overhang at top each side aligns with grooves, and you are reading the number OK from the front = it is in the right way (deeper end at back). 4. Keep searching different Google reviews and knowledge bases- with different questions.
Posted on Apr 11, 2007
  • 141 Answers
SOURCE: hp 4650n
go ahead and replace the toner cartridge because it is probably dumping magenta toner in your machine. the cause of this is most likely a bad drum cleaning blade in the toner. if you do have toner in your machine you can spray windex on a lint free cloth and wipe out the spill. or use a can of air to blow it out but be warned you may have a magenta cloud in the room for several minutes. good luck!
Posted on Sep 14, 2008
pdouglasss
  • 125 Answers
SOURCE: hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Posted on Jan 10, 2009
SOURCE: Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Posted on Aug 10, 2009
Testimonial: "Good answers - unfortunately still no closer to solving the problem."
  • 6 Answers
SOURCE: hp LaserJet 1000 series printer error message on front door cover and toner cartridge missing
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
Posted on Sep 12, 2009
10.10.00 SUPPLY MEMORY ERROR after every page prints.
This means that the printer is unable to read or find the toner cartridge memory chip. In some cases turning the printer off, removing the toner cartridge, reinstalling the cartridge and turning the printer back on sometimes correct this issue. But if that does not work, you will have to replace the toner cartridge.
Feb 22, 2011 | HP LaserJet 2420 Printer
Our HP Color LaserJet printer has a 10.10000 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0001 = Cyan print cartridge
try this:
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the cartridge.
Nov 03, 2010 | HP Color LaserJet 2600n Printer
10.00.00 supply memory error Unable to read cartridge data
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Sep 01, 2010 | HP LaserJet 2420 Printer
10.10.00 Supply Memory Error?? Unable to read cartridge data. Open and close front door to reestablish the contacts.
This is a chip error. This happens frequently when using generic brand cartridges & not OEM genuine. You will need to replace the toner cartridge
Jul 19, 2010 | HP Color LaserJet 3500 Printer
10.1004 SUPPLY MEMORY ERROR ON IMAGING DRUM Unable to read the supply data. Re-install the supply. If the error reappears, contact support.
Jul 03, 2010 | HP LaserJet 2840 All-In-One Printer
Hp 4650 supply memory error
This is caused by a faulty chip on a toner cartridge, possibly the one that you last installed. Replace the toner cartridge
Apr 27, 2010 | HP LaserJet 4650n Printer
I have a HP 4650n and when I print there is line through the middle of paper or picture. Replaced cartridges and fuser. Not sure what to do.
Probable : Dirty paper Xport rollers
Possible : Main molibdene shaft scratched (if line always same position)
Feb 06, 2010 | HP LaserJet 4650n Printer
Put new cartridge in and now it won't print
Your new cartridge is invalid. The internal Chip/memory of the cartridge is damadged.
Contact your suppier and ask to change cartridge.
Best Regards
Jun 10, 2009 | HP LaserJet 1300 Printer
Display reads "card slot not initialized"
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
HP LaserJet 4650n Printer Logo
464 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
