Question about Sebo X4 Bagged Upright Vacuum
Sebo X4 Extra brush light remains on despite changing brush, any solutions?
    President:
  • 389 Answers
Sorry you've had to wait so long for a reply. Perhaps you no longer need help, but here goes anyway. Must confess I'm not certain about this, but my guess is that the automatic height adjust mechanism (let's call it the HAM for convenience) isn't working properly. The HAM works by sensing the drag of the brush roll against the carpet, and raising or lowering the front of the machine as necessary to maintain constant drag. So first you need to check the HAM, as follows: with the handle in the locked upright position, switch on and wait for a few seconds (there may or may not be any signal from the green UP or DOWN lights). Then, still switched on, lower the handle to the normal operating position and check that the green DOWN light comes on. Wait until the DOWN light goes off and then return the handle to fully upright (switched on all the time). When fully upright the UP light should come on for a few seconds and you may be able to see the handle tilt backwards as the front of the machine rises. If this is all working properly, we need to look elsewhere for a solution. The next thing I would look for is for a broken belt. Just turn the machine over while it's running and look to see that the brush is rotating (keeping fingers and clothing well clear, of course). Sebo belts usually last 15 years or more, but breakages are not unknown.
I realise this may not exactly solve your problem, but it should give you something to work on. If you need more help, post a reply here, saying what you've found so far, and I'll try to be more specific.
Posted on May 26, 2010
Body of sebo x4 automatic not rising or falling
This could be due to the brush roller being worn.
If the brush roller is worn, then the height sensor makes the vacuum head go down fully. There still isn't enough resistance to the brush, but there is nowhere else for the height adjustment to go, so it just stays there. If you look at the cleaning head from the side you should be able to see that it is fully down.
The brush roller light is supposed to come on, but in my experience, it might not.
Feb 28, 2016 | Sebo Automatic X4 9570AM White/Gray, 10...
Orange spring will no longer hold cleaner in upright position.
You may need a replacement spring just a guess so here's the list of replacement parts with prices best of luck! Spare Parts AUTOMATIC X4 SEBO Vacuums Online Store
Jan 07, 2016 | Sebo Automatic X4 Extra Upright Vacuum...
My Sebo x 4 Extra is showing all the four lights at once. It also is rising and falling all the time on the same surface. Carpet or hard floor. It went through a spell of cutting out after several sec
If all 4 lights on the indicator panel are on at once that would usually be caused by a bad PC controller board. If your vacuum is under warranty, this should be covered. If not, I have included a link to this part as well as a parts list for your reference. This is an easy part to replace and requires only a Phillips head screw driver. http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf 5740 ER Computer Controller Windsor Sensor SR XP 86140160
Dec 08, 2014 | Sebo X4 Extra Bagged Upright Vacuum
How do I replace electric brushes in the motor
It will take far longer for me on how to do this, but I did it myself using this fantastic espares video on You Tube. Carbon brushes are really easy to remove as are other areas. X1A, X1.1, X4 and X5 Extra are all the same model, save from cosmetic differences, different motor outputs and bigger floor head and brush roller on the X5.
Nov 13, 2014 | Sebo X4 Bagged Upright Vacuum
Why won't the brush come down anymore. the brush light which should be green is off.
If its a X4 / X5, it may be time to replace the Roller Brush. The brush isn't that expensive. Also buy genuine. We well them for about $40.00 in out store.
Jul 05, 2014 | Sebo X4 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
I need a new set of instructions for my sebo x4 extra upright cleaner
you will have to call sebo or the dealer you brought it from to get manual
Aug 27, 2010 | Sebo X4 Extra Bagged Upright Vacuum
My sebo x4 extra does not start. There is power but no warning lights are flashing. When I turn the vacuum on there is a continual clicking/buzzing sound.
Hi.
Eeither motor or servo motor with gear box is seized. Testing is done energizing the motor. Test and repair must be done by a technician. Call the number listed on the owners manual to contact a qualified repairer.
See: Parts List and schematics SEBO X4
Jul 31, 2010 | Sebo X4 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
471 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
