Question about Dayton (3E386) Heater
I have a dayton 30,000 btu heater ,,it will run
I have a dayton 30,000 btu heater ,,it will run for about 20 seconds and then shut off and then I have to push the reset button to start it again,,,,what could be the problem?
  • 82 Answers
If you are pressing a small round switch with a tiny button in the center...means a bad heat exchanger. The heat from the exchangeris going where it is not supposed to and tripping a roll out switch. Have the exchanger checked for cracks or holes.....check vent pipe to make sure not plugged
Posted on May 10, 2010
I have a two year old Redstone 30,000 BTU propane wall heater. There is a lot of dust behind the unit. After running for awhile on the 2 setting, it shuts down and the pilot is extinguished.
If it is a wall unit, it has an over temp safety switch which is most likely tripping from dust preventing proper airflow across it . A good cleaning should cure this.
Feb 04, 2015 | Heating & Cooling
Spark plug fired,( Sears -30,000 BTU) starts and runs for approx. 30 seconds, then cuts off. The reset button does not reset for restart for about another 20 - 30 seconds. Then the unit will restart...
check and see if the heater has a high temperature limit switch. if it does it will shut the machine off until it cools down.. just replace it with a new one.
Jan 31, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Dec 28, 2010 | Dayton Electric Heater
I have a 150,000 BTU NATURAL GAS HEATER. IT WILL RUN FOR 10 SECONDS AND QUITS. IT WILL NOT IGNITE AGAIN UNLESS YOU SHUT IT OFF AND RESTART
The heater is not proving the flame...and shutting down on safety...
Check the flame sensor and all connections of the ground from the burner to the ignition control...
The control may also be bad...
for additional help with Dayton units go to www.grainger.com
they sell that brand and have their own repair help techs.
heatman101
Sep 17, 2010 | Dayton (2NH04502025) Heater
Dayton torpedo heater 150 btu starts and runs about 15 seconds then shuts off. Lots of fuel
All these types of heaters use mostly the same parts and dealer for one brand carry parts for most brands. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to fix your unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 12, 2010 | Dayton Heating & Cooling
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
PROCOM QL300TYLA
The QL300 has a range of 20,000 to 30,000 btus. That shouldn't be too big for your 300 square foot room with high ceilings and a loft. It has a thermostat, so it will shut off when the room gets warm. 1 pound of propane contains about 21,000 btus, so you will be burning 1 to 1.5 pounds each hour that the stove is running.
Jan 17, 2008 | Procom QL300TYLA Heater
50K BTU Reddy Heater Trips Circuit Breaker
If the unit lights Check the photo cell this can be done with an ohm meter and good light. Should have continuity in light.
Jan 14, 2008 | Dayton E50 Heater
Dayton (3E386) Heater Logo
156 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
