Question about Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC
I have just reinstalled windows xp,
Now even though other programs remain on the drive they will not open???
  • 25 Answers
I u did not have any important docs on ur pc u could have formated ur hard disk nd install a fresh copy of xp
Posted on Mar 30, 2008
  • 149 Answers
You need to reinstall the programs to when you reinstall xp you did a clean new install but put a new registry so the programs are there but windows xp does not know look for install or setup file for each program or if you have installation cd install from there..
My windows xp startup disk with the os an drivers is no good microsoft says i need contack manufactures copy do have one
You should not have contact the manufacturer (microsoft)
one of these will help you
SP3 is the third and final service pack released for Microsoft Windows XP, and it eliminates many of the security holes that previously affected XP. While Microsoft recommends that users download SP3 using Windows Update, some users are unable to do so. However, it's easy to create a Windows XP SP3 installation CD; it requires only that you download the pack from the website and burn it to a CD-R/DVD-R using an ISO burner program.
Download the SP3 installation ISO by visiting the first link listed in the "Resources" section of this article. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en XP PRO SP3 ISO Download the iso also download the imageburn http://www.imgburn.com/
http://windows-xp-pro-startup-disk.soft32.com/ http://support.microsoft.com/kb/322389 http://windows-xp-pro-startup-disk.soft32.com/free-download?gclid windows xp pro start up disc
post a reply if you need more help with this
Mar 12, 2013 | Compaq Presario sr1403wm AMD Sempron 3000+...
Won't burn DVD's after reinstalling Windows
Did you install the right drivers for the drive? It happened to me in the past where my DVD burner would only burns regular CDR's.
Jan 05, 2008 | Mitsumi DW 7801 TE (DW7081TE) DVD+RW...
Tip
When Windows XP won't start (final fix)
So--you've tried everything else and you still can't get XP up and running? Time to do a system reinstall.
If you have a recovery disk (or set) provided by the manufacturer or if you remembered to make one when you got the computer, put the first disk in the CD/DVD drive, boot from it, and then follow the prompts. The program will most likely format the hard drive and restore your computer to its original (factory) condition. Bad for you if you have not backed up your data.
When I have the opportunity, I would much rather use a Windows disk (same flavor of Windows on your machine) to install a fresh copy of the operating system. You would boot from this disk in the same manner as I described in the first two tips. This time, though, you will not choose "repair" but will proceed with the installation of a fresh copy of Windows. When prompted, I would recommend leaving the file system intact (that is, not reformat the hard drive) if you have data that you really don't want to lose. In the end, you will have two installations of Windows that you will be able to see in Windows Explorer, but only one will be functional. Your data will usually be intact. You will have to reinstall all your programs, though. All the files will be there, but no programs will work until you reinstall them.
on Aug 01, 2010 | Computers & Internet
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Jan 21, 2013 | Fujitsu Computers & Internet
My PC can't recognize my Panasonic IC recorder RR-US500
Which operating system are you using? This recorder has known issues with windows vista and windows 7 as well as Mac OS.
If you're using one of the above windows operating systems, try right clicking on the installer (setup.exe) file, select "properties". When the properties windows opens, select the compatability tab, and choose windows XP SP3 from the drop down menu, as well as click the box next to "run this program as administrator". That should run the installer as though you are running windows XP, and it should work.
Jun 06, 2012 | Panasonic Audio Players & Recorders
I had reinstall windows,now i only have 1%of disc space
You allocation of partion is too low while the time of os boot , so the only way is you have to change partion space , use this number during partition 60555 MB this 60GB so you cant get full easily , you have to run the DOS mode booting then only you can get the partition location , you may be runned the os from normal opening cd setup mode from already booted os , for further clarifications reply me , i will help you , thank you , dont forget to vote for me .
Nov 02, 2009 | Computers & Internet
Xppro on startup box appears with ref to Twonkymedia startup application error
A program that contained Twonkymedia was probably deleted. Even though it was deleted a reference remains in the start up files and when start up files are executed it can not find the program to start it thus "start up application error". To get rid of the error message you can remove the reference to the program in the start up menu or reinstall the program and let it execute normally on start up.
Oct 12, 2009 | Microsoft Windows XP Professional
Using Window XP
hello friend
I think you are suffering from a severe virus infection. Try the following steps will improve the health of your computer
  1. you should have different partition for OS and data
  2. reinstall the antivirus
  3. get a disc of the windos Xp sp2 and with that in drive type sfc/scannow
thankyou
May 24, 2009 | Microsoft Windows XP Professional for PC
"D:\ is not accessible"
Well this is kinda of a funky setup you got going with 3 drives, why dont you make a partition on the c drive to handle vista and make another partition on C: to handle xp? Run a multiboot and there you go. See vista is going to take over that secound drive no matter what, also you got to realize that its hard stating a multiboot from two diffrent drives, use your other 2 drives to store your programs and your set.
May 05, 2009 | Microsoft Windows XP Professional SP3 Full...
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
