Question about Mtd 22" Yard Machine Push Mower
Bent Shaft??? My brand new Yard Machine 22" push mower will only mow in the highest wheel setting and then only if you go REAL slow. Also has a lot of vibration in the handle. Almost like the shaft is bent/bowed. Any thoughts???
    Scholar:
  • 110 Answers
Check that the blade securing bolt is secure. While you're there, have somone SLOWLY pull the starter rope. It will be obvious if anything is bent to the extent you describe.
If this machine has a blade clutch, engage blades while you do the pull test (DISCONNECT PLUG WIRE!!!!)
Posted on May 09, 2010
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
My 22" MTD Yardman push mower runs too slow to cut much grass. How can I adjust it to run faster? It has no speed selection that I know of, only the handle bar that must be held tight to keep it running....
These inexpensive mowers are not made for large scale mowing. They're set to run as fast as they do and have low compression (read that as low power also) to make them easy to start and operate. About the only thing you can do to make it work better is keep the air cleaner clean, use fresh gas and keep the blade sharp so it cuts the grass easier. Mowing more often also means less cuttings under the deck so it works more efficently.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
My helper was mowing with my Honda push mower.. The handle started shaking.. a lot.. It will start up at first pull but is not cutting well. The blade is turning but the mower is vibrating so much it...
it sounds like the blade may have hit some thing hard .
You say the blade is turning is it turning level or is it sort of swaying as you may have ofset the drive pin.
Worst case.. new mower as it can cost a lot of money to repair drive
I know as i have done the same thing a few years ago
Aug 02, 2010 | Mtd 22" Yard Machine Push Mower
YARD MACHINE MOWER NOT A YEAR OLD YET AND IT CRUDDIES UP EACH NEW SPARK PLUG AND SMOKES, NOT RUNNING WELL. ITS RUNS REAL FAST AND THEN REAL SLOW, SPUTTERS. I HAVE ALWAYS KEPT AIR FILTER CLEAN AND OIL...
Return the mower if possible for warranty repair or call MTD with the issue. MTD mowers typically are good quality and should run like new for a long time with proper care. Depot may give you a 1-800 number instead of customer service so before you load up the mower talk to them. It does sound like a bad valve seat or rings either one is not typical wear and tear.
Jun 07, 2010 | Mtd 22" Yard Machine Push Mower
Bent shaft due to striking ground. Can a mechanically capable inidividual replace the shaft at a cost effecitve basis?
with the correct torque ratings and tools it is possible however your onna want to check the price of the crankshaft, oil pan gasket, and upper and lower seals before determining if its cost effective.
Mar 02, 2010 | Mtd 22" Yard Machine Push Mower
Riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Sep 26, 2009 | Mtd 22" Yard Machine Push Mower
Bent the blade now it pulls back when trying to pull it to start
first put new blade on. if it still pulls back change the keyway , it has bent it causing it to be out of time. it kind of easy to do just don't beat the treads up on the flywheel while tapping on it and prying up with a pry bar. i use spray to loosen the flywheel. let it soak about 15 min. happy mowing sawdust46
Aug 03, 2009 | Mtd 22" Yard Machine Push Mower
Yard Machines 22 inch mower, I dumped it on its top over the weekend, bent the blade, replaced it, now wont start, did leak oil out of the air filter, cleaned it out real well still wont start
if you bent the blade most likely you bent the crankshaft too.
Remove the spark plug and pull the rope and remove excess oil from the spark plug hole
check the spark plug for spark if you have none then a flywheel key is sheered a more in depth fix.
If you get it started you may notice a whole lota vibration due to a bent crank shaft or maybe not?
May 18, 2009 | Mtd 22" Yard Machine Push Mower
I hit a rock and bent the blade on a yard machine. Replaced the blade and tried to start the mower, but the start rope doesn't come out all the way and recoils hard as I'm trying to pull it out.
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
May 17, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
243 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
