Question about Miele T9820 Gas Dryer
Miele gas dryer drum won't turn, but turns on like it works
  • 10,319 Answers
Check out my tips on dryers
the tensioner and belt needs to be replaced more than likely
Posted on May 09, 2010
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here
http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual
price depends where you purchase it.. $ 20 to $ 45
Sep 25, 2014 | Miele T9800 Electric Dryer
I have Miele t9800 gas dryer . After 5 or ten minutes the check vent filter light blinks and beeps. Then unit turns off. No heat. The drum turns and air flows. Vent and filter have been thoroughly...
it is not sensing enough air flow. Remove the hose at the rear and check the whole pipe for fluff. Also check that the outside vent is not blocked and any opening flaps are okay.
Feb 25, 2018 | Miele T9800 Electric Dryer
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Drum still turns but no heat where do i find the heater
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
Gas dryer, no flame in the burner , dryer turns on, drum turns, no heat.
heatman101
May 07, 2010 | Dryers
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
Dryer drum won't turn but dryer will turn on like its working. no fault notice or any indicator something is wrong.
Check the drive belt. Pop the top (spring loaded) to check. If broken, remove the front panel for full access.
Thanks for your quesiton
Jan 05, 2010 | Miele T9820 Gas Dryer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Miele T9820 Gas Dryer Logo
183 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
