Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
How do you replace the water pump in the bissell 1699
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dj
Posted on Sep 30, 2010
Brushes will not turn and water does not come out when trigger is pulled.
That means that you need to replace the belts (pump belt and brush belt). Here is the belt you need and a manual you can view:
Bissell 1699 Belt and Manual
Mar 01, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water comes out the accessory hose but not the floor cleaner
I had the same problem and the heater ports were clogged. I took apart the top unit and cleaned the ports with miniature bottle brushes used to clean spray painting equipment (purchased at Harbor Freight for $4). Reassembled and the unit worked fine.
Feb 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
Water and cleaner dispenses from handheld attachment only
He could be right but most of the time when it doesn't dispense water and cleaner it means that the pump belt is worn and needs to be replaced. I would try that first (only $4.99) before I spent $100. Here is the pump bet you need, it comes with instructions:
Bissell 1699 Proheat Belts
Dec 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
The Bissell won't spray any carpet cleaner but it is still sucking up water.
If it doesn't dispense water then that means that you need to replace the pump belt. Here is a link to the belt you nee and the manual:
Dec 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
All lines are clear and the darn thing still won't
The reason it won't dispense solution is because the pump belt is worn or stretched. You need to replace it. Here is a link to the belts you need and a manual you can view:
Bissell 1699 ProHeat Belts and Manual
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
The water doesn't come out. I've taken it apart
The reason the water is not dispersing is because the pump belt is probably stretched or worn. You can get belts and view the manual here:
Bissell 1699 ProHeat Belt and Manual
Dec 03, 2009 | Bissell 1699 ProHeat Clear View Upright...
Water is not going through the machine
The pump belt may need to be replaced. You can get the belt and view the manual here:
Nov 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Pump
Check the bottom of the tank and make sure that the seal is on the valve and not sitting in the hole where the tanks sits. At the back, is the top and bottom tight together, or is there a gap, should be no gap. Is the mix valve **** turning easily or is it hanging up? Sometimes the flow indicator cap leaks air and needs to be replaced. To get to the pump, you have to take off the top cover. Look and see if any lines are pinched, if not, then replace the pump, also check the pump belt.
Mar 10, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
