Question about Sony MDS-JE480 Mini Disc Player
JE 480..I,m trying to connect it to an amplifier. The manual shows 4 rca connectors at the back, going into 4 in the amp. I only have 2 (per channel), in the amp. So I just use two into two. When i play a previously recorded(not by me) mini disk, it only plays half the track. Is this a fault in the recording, or my wrong connections? thanks! Graham
    Problem Solver:
  • 4 Answers
I am considering buying a Sony MDS-JE 480 and have read that 'Auto Pause' is not a feature on this model but can be activated with an old remote. Is this fact or simply a theory? The 'Auto Pause' feature is something I need and don't want to purchase a unit without it.
Posted on Jun 17, 2010
  • Jeff Pattison
    Jeff Pattison Jun 17, 2010
    If you don't have another disc to try you can simply check the VU meters on the player to see if both left & right channels are working. If only one working then it's a disc problem. Good luck.
    Brigadier General:
  • 8,546 Answers
Try another recording to eliminate the media as the cause.
Find the two audio OUTs (Left and Right) on the player and plug them into the Left and Right Audio IN's of any available input on the amplifier. It sounds like you're either missing one of the channels or you have them plugged into different inputs.
Posted on May 09, 2010
Why do my subwoofers not work when connected to an amplifier that is powered?
The bus connection is actually not an RCA looks very, similar i think if you look at it it will say IN. as far as i remember its an input for like a CD changer. Run a Y splitter on one of the other RCA out put, split the signal and run one to your bass amp. it does not affect the voltage in the RCA signal. i think your amp is trying to send a signal instead of receiving one.
Apr 11, 2017 | Sony CDX-GT510 CD Player
I have a AV receiver RX-V440 Yamaha and........
The title of your question reads "I have a AV receiver RX-V440 Yamaha..." yet you say you are using the manual of an RX 1020L. I will try to provide a suitable answer for both receivers.
First, a "MON" connections on an amplifier or switching unit is normally used as a line level OUTPUT from the amplifier or switch. Line level outputs are sent to RCA connectors on other TVs or amplifiers (or switches).
"MON" should not be wired directly to the OUTPUT of anything trying to "playback". It should be connected only to things that can record or allow you to see or hear what the amplifier is outputing.
Now to answer your question:
The RX-V440 is a 6.1 channel Home Theater Receiver. If you stand behind the receiver and look at the left hand side, you will see 12 RCA connectors (2 L/R by 6 high). The top 2 connectors are labeled "CD". The next set of 2 connectors are labeled "IN/(PLAY)". The third set down from the top are labeled "OUT/(REC)".
You can connect the reel-to-reel output to either CD or IN. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select CD or IN on the RX-V440.
The RX 1020L is also a multi-channel receiver. If you stand behind the receiver and look at the left hand side near the center (top to bottom) of the receiver, you will see RCA connectors labeled "AUDIO 1" through "AUDIO 4".
You can connect the reel-to-reel output to either of these. The primary purpose for "AUDIO 3" and "AUDIO 4" is to allow you to hear component video input AV1 and AV2. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select one of the "AUDIO 1", "AUDIO 2" or whatever on the RX 1020L receiver.
Nov 21, 2017 | Audio Players & Recorders
Amp stopped playing riding down the road, power light turned off. came back on when i unplugged the rca's and cuts back off when i try to plug them back in.
Faulty RCA cables, Or worse possible solution is if your amp stopped playing when it was pumping at high volume, you may have blown the RCA connectors inside your head unit Or inside your amp. If possible try another known good working amp with the wires you already have, If same happens, try different RCA cables. If problem persists after trying these, Its your head unit RCA connecters or amp RCA connectors. To rule out your amp connectors, try your amp in a friends car if possible, to rule out your head unit, try another good known working amp in your car with the wiring you already have
Mar 03, 2011 | Kicker ZX300.1 Car Audio Amplifier
How do you connect the amp with the stereo
  • Choose where to put your new amp. If you are installing subwoofers it's usually best to put the amplifier in the trunk next to or attached to your subwoofer enclosure. If you are going to power your main car speakers with the amplifier then it may be better to put the amp under the passenger's seat.
  • 2
    Purchase the following wiring for the amp: A thick power cable (the thickness required depends on the total wattage of your amp, ask a sales rep or consult your amplifier's manual for the proper gauge) that will have to reach from your battery to the amp (the power cable should also have an inline fuse to protect the amplifier); 3 feet of ground cable of equal thickness as the power cable; an RCA signal cable to carry the left and right signals from your head unit to the amp; a "remote on" wire which can be any thin wire (20 to 24 gauge) that will also run from the head unit to the amp; speaker wire (if you are powering subwoofers you should only need about 3 feet of 12-gauge wire per sub, if you're going to power your main speakers you will need enough 16-gauge wire to reach each speaker from the amp, 12 feet per speaker is usually safe).
  • 3
    Gather the following tools: Screwdrivers, wire cutters, wire strippers, pliers, a utility knife, sandpaper, masking tape with a pen for labeling, 2 crimp-on o-ring ends for the power and ground cables. If you're hooking the amp to your speakers, you'll also need 2 crimp-on female spade connectors for each speaker.
  • 4
    Find a manual with instructions on taking off the dash of your car (not the whole dash--just the head unit, in order to hook wires to the back), and also to get at your car's speakers if you are hooking the amp to them.
    The Installation
  • 1
    Disconnect the ground (negative) cable from your battery. Never work on the electrical system of your car with this connected.
  • 2
    Attach the side with the fuse of the thick positive (+/red) power cable to the connector on the positive terminal of your battery; the o-ring can be sandwiched in the bolt on the connector that connects your car to the battery. Now put the fuse in the fuse holder.
  • 3
    Run the power cable through the firewall of your car (there is usually an opening on the driver's side) and to your amplifier. If your amp is in the back it is usually best to run this wire under the plastic molding that goes along the bottom edge of your car. Be careful where you run the wire because the power cables should never be near the signal or speaker wires.
  • 4
    Find a metal bolt or screw on the metal of your car near the amp to connect the ground cable to. This should be as close to the amp as possible, never more than 3 feet. Unscrew it and clean the metal surface with sandpaper. Attach the ground to it with the o-ring and screw it back down firmly.
  • 5
    Remove your head unit and run the signal and remote on wires from behind the head unit to your amp. Connect the RCA connectors and the remote on wire to the back of your head unit.
  • 6
    (If you are installing subwoofers and not running your normal speakers off the amplifier skip to step 7.) Run the 16-gauge wire from each one of your speakers to the amplifier. On the amp side use the masking tape to label each wire so you know which speaker it is. On the speaker end-strip a 1/4 inch off the ends of the wires and crimp on the female spade connectors with your pliers. Connect the spade connectors to your speakers making sure to match the positive (+/red or white) with the positive terminal and the negative (-/black) with the negative one.
  • 7
    Connect everything to your amplifier. Only strip off as much as you need off the end of each wire to make a solid connection, you don't want any exposed wire hanging out. If you have subs, attach them to the amp with the 12-gauge speaker wire.
  • 8
    Secure your amp to something. If it is in the back you can screw it directly to your subwoofer enclosure. If it is under a seat you may just want to get some straps that hold it down.
  • 9
    Reconnect your car's negative cable to the battery. Test your system and make sure everything works, going around to see that every speaker is on before you put everything back together
  • Feb 17, 2011 | Car Audio & Video
    Will this amp push 2 2000 watt subs?
    hope this helps.
    caution
    About Power supply wires (MRP-M1000 only)
    • 21mm2 is the minimum power and ground cable size
    that should be used to connect this amplifier. The
    length of these cables should not exceed 1m to assure
    safe operation.
    • If the length of the power and ground cables exceed
    1m, or if you connect more than one amplifier, a distribution
    block should be used with 33mm2 or 53mm2
    power and ground cables depending on the length
    necessary. Ensure that you install a correctly-rated
    in-line fuse on the power cable near the battery positive
    post.
    RMS Continuous Power (at 14.4 V, 20 - 200Hz)
    • Per channel into 4 ohms (?1% THD+N)
    MRP-M1000 ......................................... 600 W x 1
    MRP-M500 ........................................... 300 W x 1
    • Per channel into 2 ohms (?1% THD+N)
    MRP-M1000 ....................................... 1000 W x 1
    MRP-M500 ........................................... 500 W x 1
    Total MAX Power
    MRP-M1000 ............................................. 1900 W
    MRP-M500 ............................................... 1100 W
    S/N Ratio
    • IHF A Weighted, Reference: rated power into
    4 ohms .................................................... 100 dBA
    Input Impedance
    • RCA IN .................................................. 20k ohms
    • SP IN .................................................... 40k ohms
    Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
    Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
    Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
    Dimensions
    • Width (Heat Sink/Footprint)
    MRP-M1000
    ......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
    MRP-M500
    ............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
    • Height ..................................... 60 mm (2 - 23/64")
    • Depth .................................... 242 mm (9 - 17/32")
    Weight
    MRP-M1000 ................................................ 4.2 kg
    MRP-M500 .................................................. 2.7 k
    Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
    How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
    :) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
    Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
    Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
    for example a basic music system is
    1 cd player
    1 pre amp
    1 amplifier (4 inputs, 4 channel out)
    you bridge 1+2 and connect this to 1 12" double coil sub woofer
    the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
    Thats a kicking tricked out basic car audio system,,,
    Hope that helps you understand how it works..
    Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
    I have a jvc kds580 and i wanna run a passive Bazooka EL and 4 other speakers. Can i drive the sub with the 2 RCA OUTS on the back of the unit? If not, how do i drive the sub?
    RCA Outs are very low power signal connectors. They would have a hard time running a pair of headphones.
    What you need is a Power Amp that the RCA's plug into and your subs Connect to.
    You need an Amp (Amplifier) that powers a similar number of Watts to what your Subs Capacity is. (ie; your subs have a ratting of 100W (Watts), then you need an amplifier with 100W per channel; that's a 200W amp for a two way (Speaker) amp, or a 400W rating for an amp with 4 channels (4 Speaker connectors)
    You can run a lower power amp on your subs, and use ony a portion of your speakers capacity; but if you get an amp that supplies more wattage than your speakers capacity, then you'll blow your speakers, their performance will deteriorate slowly. eventually they will not be able to generate a clear reproduction, Speakers are irrepairable.
    Sorry for the long explanation.
    This is something you wan't to do right, the first time.
    Cheers,
    Richard.
    Jun 21, 2009 | JVC KD-S580 CD Player
    Legend Amp hook up manual.
    Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
    Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
    Run the REM to your stereo power ant. Wire. if available.
    Run the GND to Metal Chassis Ground keep it as short as possible.
    Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
    This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
    There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
    Hope this helps
    Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
    Crown amp xs900 will not reset
    naz, get a hold of crown, tell them whats up. check all fuses and connections first. the unit is worth $900.00. they should be a little understanding.
    Features
    • 2-ohm dual (per channel) : 1200W
    • 4-ohm dual (per channel) : 900W
    • 8-ohm dual (per channel) : 600W
    • 4-ohm Bridge : 2500W
    • 8-ohm Bridge 2100W
    • Indicators for : Signal, Clip, Power, AC Mains, Fault, Bridge, Temp.
    • Housed in a rugged, all-steel 2U chassis
    • Microprocessor-controlled protection system.
    • Flow-through ventilation from front to back.
    • Internal heat sinks with forced-air cooling for rapid, uniform heat dissipation.
    • EIA Standard 19-inch rack mount width
    • Safe with all types of loads.(2 to 8 ohms in Stereo, 4 to 8 ohms in Bridge Mono.)
    Inputs
    • XLR-¼" combo connectors: One per channel
    • 3-pin female XLR connector and TRS ¼" phone jack accept balanced or unbalanced signals.
    • 3-pin Phoenix-style connectors (2-channel models only),One per channel, accepts balanced or unbalanced signals.
    Output
    • Balanced XLR connectors (2-channel models only)
    • One per channel, 3-pin male XLR connector in parallel with XLR-¼" combo and Phoenix-style input connectors for daisy-chain operation.
    • 5-Way binding post output connectors: One pair per channel; accept banana plugs, spade lugs or bare wire.
    • 4-Pole Speakon output connector (2-channel models only)
    • Accepts a 4-pole Speakon connector.
    Dec 31, 2008 | Crown XS900 2-Channel Amplifier
    How should I wire up this amp and sub
    The amp's not actually a very good match for the sub, since the sub can be wired for 2 ohms or 8 ohms, and the amplifier is most efficient at 4 ohms in bridged mode. My advice would be to wire the amp in bridged mode, and wire the sub for an 8 ohm load. To do this, the amp's (+) wire should go to the (+) terminal on one of the sub's voice coils. Then run a wire from the (-) terminal on the OTHER voice coil to the (-) terminal on the amp. The remaining (+) and (-) terminals (on opposite voice coils) should be connected to each other with a wire. Your original wiring setup had the amplifier connected to only one voice coil, while the other voice coil was shorted.
    Jun 10, 2007 | Kole audio Q2-480 Car Audio Amplifier
    Sony MDS-JE480 Mini Disc Player Logo
    128 people viewed this question
    Top Sony Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
