Question about Samsung LN-S4041D 40 in. LCD HDTV
Takes a long time to come on
Picture takes a long time to come on / warm up
    Guru:
  • 416 Answers
You have bad capacitors on yor power supply board. This is a common problem and can be fixed easily if you can use a soldering iron and have a Radio Shack near by. I published a tutorial on this repair in my Tips & Tricks, check it out if you want to give it a try yourself. Otherwise, you will need to contact a service repair facility and have the power supply repaired. Best wishes, I hope this was helpful.
Posted on May 09, 2010
Testimonial: "thanks very helpful"
  • sonic boom electronics
    sonic boom electronics Dec 29, 2010
    milkburp :::: i just read your info on testing a remote by digital camera i must say 26 yrs in this industry i have never seen it take a bow son well done
    take care sonic boom electronics
I have a flat screen samsung that takes about 15 seconds to come on. after the picture appears it is fine. do you have an answer for this problem.
Actually the pictures get displayed on your screen when electrons from an electron gun fall on the fluorescent material coated on the screen. The electron gun usually takes a warm up time which is about 5-10seconds. But since this warm up time is longer for you, i suspect that it is a loose connection to that electron gun.
Apr 13, 2010 | Samsung LN-T4665F 46 in. LCD Television
TV Flickering, Wave, and Warming Up Problem
The capicators in the hyperboard have failed. An esy fix if your patient. Otherwise I offer a repair service. Let me know.
Feb 03, 2010 | Toshiba 50H81 50" Rear Projection...
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Sony trinitron flickering
Sony Trinitron it 36 fiickering
Sep 13, 2008 | Televison & Video
Poor quality pictures
Check your picture settings, the wrong setting for the time of day or object can definetly throw off the appearance of your pictures. Plus, you may have accidentally set it to "warm" instead of auto or black and white, etc. Warm pictures have a reddish tint to them just as the cool have a blue tint. Also I have found the "night setting" only takes really good pictures if you are close to the subject otherwise it is pretty dark!
Aug 16, 2008 | Kodak EasyShare CX7330 Digital Camera
LCD rear projection takes a long time to warm up
If you are talking about the picture, and it takes a long time to fade in to full brightness, then the LAMP needs to be replaced. Call the Maufacter or repair shop to get one.
May 26, 2008 | Samsung Televison & Video
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Samsung LN-S4041D 40 in. LCD HDTV Logo
905 people viewed this question
Jerry Greenberg
Jerry Greenberg
