Question about Bruder Cat Skid Steer Loader
I have a bobcat 863 it will try to start but wont turn over
    New Friend:
Is it gas ?do you have spark?
Posted on Jul 11, 2013
  • 26 Answers
Makes a click but wont turn over check the starter aint locked up.
Posted on May 10, 2010
Can I find out what year a Bobcat is by the serial number?
look here
http://www.bobcat.com/company-info/help-center/faq
Apr 03, 2017 | The Optics
My 863 bobcat brush mower loses power in heavy grass. I rebuilt the pump on brush cutter. I hooked up auger and the guger turns slow like hydraulic flow is low. what should I ck.
I would flow test the pump to be sure that there are no seals that are bad or also if any of the valves in the pump are bad. If any of the valves are bad you can test the spring pressure of that valve to make sure it is within the correct specifications in accordance with the technical manual for your specific pump.
Nov 08, 2016 | Bobcat Garden
How do I fix as bobcat 863 deutz running issue
diesel engine give good service provided that the fuel is clean and with no air in the system
the problem can be air in the fuel lines to the pump, blocked filters , vent problem at the tank.
diesel fuel suffers from a moss growth in the fuel tanks which blocks the filters and can cause injector tip problems
As the engine starts and runs I would change the fuel filter and bleed all the air out for a starter
you may also drain the water trap under the filter or in the water separator filter before the filter
If you see evidence of the moss ( brown slimy looking substance in the filters ) use a good quality diesel fuel conditioner to kill it off
Sep 18, 2015 | Toys
I have a bobcat 863. Sometimes it will not shut off when I turn it off. Any ideas?
Bobcat 863 863H Service Repair Manuals - YouTube
? 3:17
www.youtube.com/watch?v=Hsp-NAdM4Sg
Oct 30, 2010 - Uploaded by DiyRepairManuals
Bobcat 863 863H, Service Manual, Repair Manual.
Sep 15, 2015 | Toys
Bobcat 863 starts, runs but, wont move or raise?
What is bobcat863 a play name on a online game
Jan 28, 2015 | Toys
I have an 863 bobcat, I shut it off for just a few min, then when I tried to start it back up it turns over but won't start, I tried starter fluid which will start it but it will only run for a few seconds
I presuming it is a diesel bobcat, if so then your fuel solenoid has failed, you will need to replace the solenoid, it a large nut with a wire coming from it and it's located on the fuel injection pump,
Jul 24, 2014 | Cars & Trucks
Where is fuse box on a bobcat 863 ?
In the rear compartment down on your right under a couple dust covers.
Mar 23, 2011 | Bruder Cat Skid Steer Loader
I have a bobcat 863, turns over ok, but will not start. Did not run out of fuel.
the fuel intake is from the top of the fuel tank, there is a tube which goes to the bottom of the tank. This tube may have deteriorated and come off or have a crack. You can lift the cab and reach down to the tank to pull the plug to check. good luck
Jan 27, 2011 | Bruder Cat Skid Steer Loader
What do you have to remove to get to the fuel tank on 863 bobcat
for remove the bobcat fuel tank you need remove first the motor or if do you want to clean the fuel tank you only need remove in the botton side the steel bar with 3 screws and remove the fluel tank plug.
Jun 25, 2009 | Bruder Cat Skid Steer Loader
Bruder Cat Skid Steer Loader Logo
1,096 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
ptpumpman
Are you a Bruder Toy Expert? Answer questions, earn points and help others
