Question about Northstar 6000I GPS Receiver
My Northstar 6000i is having problems, some of the soft keys are not working? How can I fix this? WIll a master reset or software download fix my problems? Or do I need to get the unit fixed by delaer?
3 Suggested Answers
  • 43 Answers
SOURCE: yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Posted on Oct 15, 2009
  • 503 Answers
SOURCE: leak inside gps
Leak inside a gps is usually just a battery, sometimes they overcharge for to long and when happens the battery deforms and leaks. I have no idea where to send them to for repairs, bbut usually they are not that complicated to get into them and remove and replace the battery, they batteries in most gps units are the same size and usually the same shape as cellphone batteries, they just have different connections on the outside of them, but the insides are usually the same, also you might have one that you can run without the battery in it. I would suggest that you might want to open (if no warranty on it) up carefully, remove the battery and see if you can run it that way. Be advised though that if you do this, any power interruption to the unit while you are driving will cause it to shut down and you will have to start your trip entry all over again. Hope this helps.
Posted on Apr 26, 2010
How do I get some keypad buttons working on my 6000i Northstar chart plotter?
good luck with that most companys wont repair there systems they update you to a newer one for about 500 dollars more
Mar 29, 2013 | Northstar 6000i 12" Color Display With...
Enter button does not work
bad key pad common on that unit sorry
I have a Northstar 6000i that will not display the tide track information. It has for 3 years,and now has a message stating that it can't display the information for the current date.
Probably the data didn't go past 2010. I have a Northstar 951XD, and first time out this year, no more tide track data - my manual says it only went fron 1994 - 2010. So how to get updates?
May 15, 2011 | Northstar 6000I GPS Receiver
How do I get a manual for a 6000I?
Retrevo has the manual to the NorthStar 6000i here: http://www.retrevo.com/support/NorthStar-6000i-GPS-manual/id/534ag415/t/2/ . You will need to enter a code to download the PDF. This is the Quick Start Guide and the Reference Manual.
I hope this helps.
Apr 30, 2011 | Northstar 6000I GPS Receiver
My 6000i gps willnot load charts
Greg,
Let me know if want to sell your Northstar for parts. I have a dead unit and need a main board. All else works fine but the repair at the catory is $799.00 which makes no sense.
bobanderson_2000@yahoo.com
Dec 06, 2010 | Northstar 6000I GPS Receiver
Leak inside gps
Apr 26, 2010 | Northstar 6000I GPS Receiver
My 6000i flashes No Engine Data
I researched my problem on the web, found several posts on various forums that helped. Bottom line, I determined that my 6000i installation did not include a gateway. I did that by eye balling the system after removing some panels.
Jan 30, 2010 | Northstar 6000I GPS Receiver
Yes my northstar 6000i keeps losing gps signal
Aug 27, 2009 | Northstar 6000I GPS Receiver
T mobile wing
The T-mobile wing,which won't make a sound anymore. You'll wanna back up your content to your PC using the software provided. Active Sync Window 6.0. You can dowload it from www.htic.com/activesync for free. Just connect via USB cord. Once that is all backed up, do a hard reset.
aster Reset for a HTC Pocket PC: Warning: Performing a Hard/Master Reset will remove all of your data (settings, files, 3rd party applciations, etc.) from your device and will only reload the Windows Mobile Software and components. The method for Hard Resetting/performing a Master Reset on HTC devices can vary by model. Below are the instructions for the most common method. If these steps do not work for you, consult your user manual or contact your wireless carrier for additional assistance.
  • With the device powered on, press and hold the Left and Right Soft Keys.
  • Whilst holding the Left and Right Soft Keys, perfrom a Soft Reset on the device by inserting the stylus into the reset hole.
Feb 04, 2009 | T-Mobile Wing™ Smartphone
I-mate jasjam frozen
Hi rossei. this is jamie. I have had this problem for long time but now I tried some else which really worked for me, I hope this works for you too. Well to make it short, disconnect your i-mate jasjam's battry and take your sim card out from your i-mate jasjam and leave it for about 10 to 20 minutes then reconnect every thing back together. There you are, thats fixed now. Its not really 100% solution for this however it works on mine but I do this procedure all the time to get it working, Good luck
Sep 24, 2007 | Apple iPhone 3G
Northstar 6000I GPS Receiver Logo
140 people viewed this question
Top Northstar GPS Experts
Jose Ma DM.
Jose Ma DM.
Are you a Northstar GPS Expert? Answer questions, earn points and help others
