Question about Kenmore 22062 Top Load Washer
The message is "ob" on the screen. all the clothes are out of the washer and have reset however message continues to come back
There is water leaking out of a piece of plastic in the back of the washing machine it will not go any further than 23 minutes we keep getting the message ld and ob
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#!!##
Jun 15, 2010 | Whirlpool Calypso GVM9959K Top Load Washer
Whirlpool Calipso model clothes washer shows a LD and doesnt run
Jul 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*(@$&
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
I own a kenmore elite heavy duty plus washer. During operation it stops and a message apears saying ob when you open the lid and close it ob disapears and I restart it and minutes later the timer never...
The OB error code is short for out of balance. There are two fixes that you can try: One is to move the clothing around in the tub. or Two the machine isn't level and is causing it to falsely error as out of balance.
Oct 30, 2009 | Washing Machines
Washer says "ob" and there aren't any clothes in the washer
some machines can be over loaded and under loaded u need to take the clothes out and run it with nothing in if it does it again with nothing in the sensors are faulty and u need an expert to check it for u
Jul 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stopped running and draining "OB"
Jul 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22062 Top Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
