Question about Kenmore 65924 Electric Dryer
I replaced belt on my dryer, but it wont spin on its own. It does spin with hand assisstance
    President:
  • 2,468 Answers
Check the idler pulley near the motor that keeps tension on the belt,they lose their spring tension or break and you lose belt tightness on the drum
Posted on May 09, 2010
  • 10,319 Answers
The belt may not be installed on the belt tensioner correctly
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
Motor runs, but clothes tub will not spin, what is the problem? There is a vynyl looling inch belt on the tub.....tub spins freely with hand control.
either the belt slipped out of the idler pulley or the belt itself broke,, click on this link for easy instructions for your machine http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm please take a moment to rate my response Thanks good luck
May 30, 2011 | Whirlpool LER4634J Electric Dryer
Dryer is heating but drum is not turning. What is the problem?
I would say belt is broken, if you turn the drum by hand and it spins freely then that is the problem, here is a website that will help:
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Dec 24, 2010 | Kenmore Dryers
My clothes dryer wont spin
broken belt. If you want to do it yourself you will probably need a few simple hand tools and a trip to sears or an appliance place for a belt. check to make sure though. see if you can here a motor working. if you do than it is the belt.
Aug 28, 2009 | Kenmore Elite HE4 Electric Dryer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Whirlpool Dryer wont spin
If it heats but doesnt spin, most likely the belt. May not be broke though. May have fallen off. Let me know if you need more help.
Dec 16, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer wont spin
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Aug 27, 2008 | Dryers
Kenmore electric dryer
Belt
Motor
Door switch
  • Remove the belt.
Kenmore 65924 Electric Dryer Logo
96 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
