Question about Rheem Paloma PTG-42PVN / RTG2-42PVN Natural Gas Indoor
Starting unit very difficult
Model: PTG-42PVN
SN: PJNG 0904P000024
Unit purchased at HomeDepot.
The burner ignites for ~3 secs., goes out then lights again for ~3 secs. then flashes C2-11.
It has always had problems, which I thought were due to a very old undersized gas line from the meter to the house.
This has now been replaced, but the problem still exists and is getting worse.
The gas and water pressure are good, the electrical ground is good, and the vent is clear. The vent is vertical and is only ~18'' long.
  • 1 more comment
  • vakog May 10, 2010
    I think I may have fixed it =;-)
    Disconnected power, gas and water off.
    I took the front cover off, then the circuit board cover.
    Removed 2 screws holding board in.
    Removed quite a few screws holding burner chamber cover. BE CAREFUL NOT TO DAMAGE THE GLASS FIBER GASKET.
    Removed screw that holds control panel.
    Checked all hoses were okay and well connected to sensors etc.
    Disconnected and blew out short hose that checks room pressure, this has a small brass jet in the end of it.
    Fasten control panel and circuit board back in place and put the cover back on. Ensure board does not touch anything it shouldn't e.g. on my unit the cable clamp behind, center top, where the board sits was proud and caused the board to bend when screwed down.
    Turn water on and power up. Switch faucet on, fan blows for several seconds then shuts down with A1 error, that's expected as front cover is off. Repeat a couple of times.
    Power off. Took a toothbrush and cleaned flame rod (right hand side of burner) and spark plug (left hand side of burner). Cleaned burners.
    Repeated fan blowing a couple of times.
    Replaced burner cover. BE VERY CAREFUL AND MAKE SURE THE GLASS FIBER GASKET IS IN PLACE AND IS EVEN.
    One of the screws stripped the thread, so I replaced it with a #6 stainless screw and nut. The screws need to be fairly tight as if the cover leaks a) it's dangerous and b) the unit may not work correctly (I think this may have been part of the issue for me).
    Replace front panel.
    Turn on gas, water, and power. See if it works any better...
    In my case it seems to be working (for now !)
  • vakog May 16, 2010
    My bad, I described the position of the the flame and ignition plugs the wrong way around !
    It should be:
    "flame rod (left hand side of burner) and spark plug (right hand side of burner)..."
    Just an update it's still working perfectly =:-)
    I don't think it was the thermocouple, as it would nearly always start straight up first thing in the morning. I hadn't noticed this, my wife told me about it during this week !
  • 349 Answers
Check your thermocoupling, because it seems like it isn't sensing the flame.
Posted on May 12, 2010
I have a paloma tankles water heater model #ptg-42pvn i am getting an intermitent error code C4,12. what is the problem?
Copy following link for Rheem-Paloma tankless troubleshoot and error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
If unit worked before: Maybe bad PC board. Maybe lack of required yearly maintenance.
Common error codes can be caused by not following maintenance protocol such as cleaning combustion parts, checking gas pressure, checking venting, and air intake, bleeding gas line etc.
Too bad Rheem-Paloma manuals do not show HOW to conduct this maintenance, leaving customer with many unknowns, and no way to oversee that maintenance performed by hired technician is complete, and matches recommended maintenance.
Sell unit on ebay, and install tank-type gas water heater.
Mar 20, 2013 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
My PTG-42PVN h20 heater is allowing h2o temp to fluctuate from one extreme to another.
Does same thing happen at all faucets?
Are you getting error code?
You might have crossover problem with defective faucet cartridge.
Copy following links for troubleshoot resources:
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Aug 08, 2012 | Rheem Water Heaters
Getting a error code C2 82 on PTG-42PVN / RTG2-42PVN Natural gas indoor
This error code will occur for two reasons:
1. The heater has lost its programming and you will need a new programming chip from Rheem. (866) 720-2076
2. The igniter module is located behind the Printed Circuit board and will need to be relocated.
Apr 10, 2012 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
What size venting do I need for the ptg-42-pvn?
3" category III stainless for special venting
Tanklessking shows Category III stainless steel vent kit for this model
3" vent
http://tanklessonline.com/rheem-water-heaters-RTG42.html
ptg-42-pvn has minimum 31,000BTU and max 118,000BTU
Max water temperature 120 degrees F
Spec sheet says: 3" special venting
http://www.palomatankless.com/products/42/specifications.html
Hart and cooley show special vent 3" stainless thru-the-wall vent
http://www.hartandcooley.com/specialgasvent/PDF/851515%20Tankless%20Water%20Heater%20Installation%20Vent%20Kits%20sell%20sheet%20-%20HC%20-%20low%20res.pdf
Hot water sources shows thru-wall or thru-roof
http://www.hotwatersource.com/RTG42PVN-Rheem-Indoor-Natural-Gas-Tankless-Water-Heater/RTG42PVN,default,pd.html
http://waterheatertimer.org/pdf/Tankless-roof-vent-installation.pdf
Aug 17, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Model# PTG2-42PVN serial# PJNG 0807900234 error code C776
Before calling service technician, open following link for Rheem troubleshooting resources.
The same error code, and apparent problem, on one person's tankless unit can have different cause and solution than another tankless unit.
Repair most tankless problems yourself, same day, any brand, for about $330
http://watergheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 10, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-42PVN, No hot water. error C4 56 can u help?
get ready to pull that one out and get a different brand
worked on mine for a year and a half and replaced everything and the unit would still not run.
Jan 19, 2011 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
Model PTG-42PVN
According to the symtoms...sounds like you have a problem with the flow control valve. If less than 3 yrs old, contact Rheem Customer Support at (800-432-8373) and they can an authorized tech in your area to service the unit.
If the unit is out of warranty, I reccommend you still call customer support to find a local technician. Unless you're highly technical/mechanical, this is not a problem you should attempt yourself.
Thanks for trying Fixya.com
Mike...
Jan 30, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have Paloma Model PTG2-42PVN it shuts off and remote flashes C7 and 13.What can I do?
call the toll free number 800) 432-1549, they will mail you a 11 or 14 page manual to clean the burners... big job, but it works!
Oct 06, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma PTG-42PVN /  RTG2-42PVN Natural Gas Indoor Logo
626 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
