Question about Hammering
Manual wanted for lombardini 914 2cylinder air cooled diesel
2 Suggested Answers
faceofftech
  • 185 Answers
SOURCE: need user manual mfor Lombardini 6LD435/B1
here is a link for the the 2 manuals there is 2 similar engines yours should be the first one, as you may know the company is in Italy but they have distributors in the US here is their website
If it works for you, don't forget to rate me
thx
Posted on May 26, 2010
Can i fit a extra water trap filter to hyundi terrican 2004 2.9 diesel
you can fit or have fitted any number of water traps to the vehicle
what you have to ask yourself is why am I getting so much water in the fuel
diesels use fuel to lubricate and cool the injectors and this fuel gets hot
it is returned back to the tank where the cool air in the tank forms into droplets of water and over time contaminates the fuel system
How to avoid the water forming--- change from leaving the tank half empty or less to running it at least 3/4 full or more when not in use
Less air space = less water
use a quality diesel fuel conditioner also helps
May 29, 2017 | Cars & Trucks
Which size of feeler gauge do we use for td42 valve tappet clearance
the engine make would be a help but generally if it is petrol ,water cooled --.010" hot inlet and .012" hot exhaust
if diesel then .012" inlet hot and .014" exhaust hot
if air cooled petrol then same as for diesel
best if you get a workshop manual and check for specifics.
Jun 08, 2015 | Cars & Trucks
How do i reduse the flow on my diesel pump on a citroen berlingo vna thanks
I am not sure why you should want to reduce the capacity of your diesel pump. Perhaps you would enlighten me?
The diesel system always has a surplus capacity to allow more diesel to be pumped to the injectors than they could possibly need. This cuts the chances of vapour locks, air bubbles, cavitation and suchlike and as the surplus is returned to the fuel tank it is also an essential part of the cooling of the fuel system and it is for this reason, certainly in hot weather, it is unwise to operate a diesel engine with less than half a tank of fuel.
In the case of a conventional diesel pump the surplus fuel flow is governed by valves and graded holes but in the case of the modern common rail system the flow is mostly controlled by a pressure regulator and the rail pressure is constantly monitored by the engine management system via a pressure sensor.
Feb 20, 2015 | Citroen Berlingo Cars & Trucks
Lombardini 6LD435 Gen Air filter where can I get one
I would go to the fine cars ask for advise .
Jan 30, 2013 | Cars & Trucks
Need user manual mfor Lombardini 6LD435/B1
thx
May 26, 2010 | Electrical Supplies
Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Oct 19, 2009 | Electrical Supplies
Diesel manual does not include my watch! DZ7091
c05b449.jpg451a77f.jpg I have a booklet of these watches in 30 pages, in English,Italoano,Deutsch,Francais, and Espagnol. Contact: joe3ssen@wxs.nl
Dec 13, 2008 | Diesel Audio Diesel Watch
Tectaloy extra cool 2000
http://www.tectaloy.com/images/documents/Tecinfo%20Book4.pdf
This is there own spec manual , However as a general rule most automotive grade antifreeze works fine in diesels. Your own owners manual will tell you if there is one kind you shouldnt use.
Dec 12, 2008 | 1999 Hyundai Accent
Hammering Logo
872 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
